f4istunna Posted December 12, 2010 Author Report Share Posted December 12, 2010 was cleaning out my basement yesterday and found another box of banshee parts. Also found a few sets of spare handlebars, stock silver yamaha rear wheels 4x115 if anyone is interested. $10 per pair of handlebars, most are steel one peice moose, msr or similar, have a cpl aluminum, renthal and nice set of tapers $20 per set. $30 for the pair of stock yamaha rims. -Frame straight and solid needs new paint or powdercoated. Has footpegs welded on $50 (local pickup) -Stock swingarm with axle carrier and stock linkage (bearings included but not sure condition) $30 -Seat with black Factory effex (FX) gripper cover. has one tiny tear (smaller than pinky nail) good pan, foam and latch $25 - Purple rear fender has a crack a few inches long behind seat and faded but useable, yellow tank plastic, and yellow radiator plastic $20 obo will ship take and rad plastic but prefer local pickup if you want the rears - Stock gas tank with cap and petcock $10 - 3 Rear sprockets 41 tooth with sprocket hubs, and one 15t front sprocket $10 all -Swingarm pivot bolt $5 Headlight/fender mounts $5 - Factory concepts billet clutch basket with complete clutch. Good plates, hub and pressure plate, bolts/springs and hardware inc. Bolts on gear on back of basket are grinded down some but worked fine basket has no grooving just normal wear. $50 - ( 2 ) Front brake master cylinders / levers with lines $20 - Stock clutch lever with cable and parking brake cable $10 - Kicker gear/spring assembly $5 - Front wheel hubs with rotors $20 - Rear wheel hubs $30 - left and right spindles $30 -Aluminum ac grab bar $20 -Stock radiator $5 - Rear brake hub and rotor $10 - Clutch cover with waterpump and stator cover *(stator cover has damage but useable) clutch cover/waterpump good $10 -shifter shaft $5 misc hardware engine mounts, chain tensioners .... if anyone is interested in taking it all shoot me an offer on the whole lot. i have pics of everything but couldnt get them to upload. ill try again later when i get home or send your email if you want to see anything thanks Quote Link to comment Share on other sites More sharing options...
f4istunna Posted December 13, 2010 Author Report Share Posted December 13, 2010 clutch seat Quote Link to comment Share on other sites More sharing options...
f4istunna Posted December 15, 2010 Author Report Share Posted December 15, 2010 sold the front hubs/rotors . Still have the rest of stuff on the last list. Quote Link to comment Share on other sites More sharing options...
f4istunna Posted December 16, 2010 Author Report Share Posted December 16, 2010 Clutch assembly Sold Quote Link to comment Share on other sites More sharing options...
f4istunna Posted December 16, 2010 Author Report Share Posted December 16, 2010 Seat sold Quote Link to comment Share on other sites More sharing options...
831Racing Posted December 23, 2010 Report Share Posted December 23, 2010 Bought this bike early this summer and havent had a chance or much extra $$ to do much with it. It ran when i bought it but low compression on right side. Tore down and found the modquad head have a small chunk missing around a bolt hole where someone put a bigger bolt to replace stripped stud. I planned on redoing the whole bike over winter and reselling next summer but its not gonna happen anytime soon we just had a newborn son and could use the money now so just decided to part this one out. Located near youngstown ohio if local feel free to pickup. I can ship no problem some of the parts are already boxed up and on ebay. Some i still need to find time to clean up and look over good before i list. Prices are plus actual shipping to your zip. If shipping i can accept paypal or money order. I will ship your parts by next business day at the latest after payment clears. -Pro circuit platinum pipes with silencers. Right pipe has half dollar size ding, one of the silencers has a loose or broken inner core you can hear it rattle. Im sure they need repacked. Pipes look good overall. I cleaned them up a little with steel wool but they will come out better with some elbow grease and polish. $150 - Keihin pwk carbs with thumb throttle and cable. I measure them at just under 29mm (28.80) so not sure if just considerd the common 28's or 29mm? Choke knobs work good, no stripped screws. Cable seems good. thumb throttle cover is missing 1 screw $150 - Lonestar extended axle. some surface rust but axle is straight, good splines and threads. Comes with 2 1" spacers, stock locknuts. Measures 39" end to end. $125 - Complete rear brake system. Caliper, stock line, master cylinder lever and resi. Brakes worked, no leaks. Lever could use painted. $90 - Stock ignition coil good spark $20 - Kicker lever and knuckle still seems pretty tight. $20 - Left and right stock spindles. Straight with good threads $35 - Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included. - Airbox with pro flow and KN Airbox has 1" hole on each side with screen, good lid and clamps. 1 damaged tab on box but mounts solid. K&N filter is well used but has some use left. Pro flow adapter in good shape. Intake boots included. $30 - Aluminum rear grab bar Not sure the brand straight and solid $20 - Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $25 - Rear brake hub and rotor Rotor straight hub looks good $20 - Stock front shocks 14" red springs, good shape not blown. $70 - Stock radiator no leaks, has a few fins flattend out here and there $15 Thats all ive had time to clean up and get boxed up for now. Hopefully this weekend i can get to the rest. Frame looks good no cracks, needs paint or pc, the pegs are welded on , good engine cases, cylinders need a few studs helicoild i still need to measure bore, trans shifted good. Plastics are pretty rough, wheels and tires im keeping for my other one. good seat, Also have extended a arms not sure what brand . heres a link to some of the pics i have as of now. Will get pics of the rest asap. http://img94.imageshack.us/g/1048603j.jpg/ http://img94.imageshack.us/img94/4615/1048603j.jpg axle http://img843.imageshack.us/img843/4134/1048605.jpg axle http://img220.imageshack.us/img220/5531/1048594.jpg exhaust http://img841.imageshack.us/img841/7192/1048596.jpg exhaust http://img835.imageshack.us/img835/1504/1048568.jpg carbs http://img560.imageshack.us/img560/1281/1048562.jpg carbs http://img295.imageshack.us/img295/8738/1048561.jpg rear brakes http://img840.imageshack.us/img840/7408/1048541.jpg kicker http://img266.imageshack.us/img266/7409/1048623.jpg front shocks http://img826.imageshack.us/img826/2623/1048627.jpg radiator http://img269.imageshack.us/img269/3931/1048632.jpg grab bar http://img198.imageshack.us/img198/9513/1048642.jpg airbox/pro flow ********do you have the fly wheel,and the stator and a soft seat. if you can please give me a call at (831)210-3147 thank you. Quote Link to comment Share on other sites More sharing options...
f4istunna Posted December 26, 2010 Author Report Share Posted December 26, 2010 ********do you have the fly wheel,and the stator and a soft seat. if you can please give me a call at (831)210-3147 thank you. thats all sold sorry. just have whats on the list above on this page aside from whats been marked as sold in the posts following the list. Quote Link to comment Share on other sites More sharing options...
yooperbanshee Posted December 26, 2010 Report Share Posted December 26, 2010 how much for the rear hubs, yellow tank and yellow rad. plastic shipped to 49837. Quote Link to comment Share on other sites More sharing options...
Tankdogg Posted December 30, 2010 Report Share Posted December 30, 2010 Do you still have the pro circuits and the kicker? How much For both plus shipped to Texas? Quote Link to comment Share on other sites More sharing options...
