Bought this bike early this summer and havent had a chance or much extra $$ to do much with it. It ran when i bought it but low compression on right side. Tore down and found the modquad head have a small chunk missing around a bolt hole where someone put a bigger bolt to replace stripped stud. I planned on redoing the whole bike over winter and reselling next summer but its not gonna happen anytime soon we just had a newborn son and could use the money now so just decided to part this one out.
Located near youngstown ohio if local feel free to pickup. I can ship no problem some of the parts are already boxed up and on ebay. Some i still need to find time to clean up and look over good before i list. Prices are plus actual shipping to your zip. If shipping i can accept paypal or money order. I will ship your parts by next business day at the latest after payment clears.
-Pro circuit platinum pipes with silencers. Right pipe has half dollar size ding, one of the silencers has a loose or broken inner core you can hear it rattle. Im sure they need repacked. Pipes look good overall. I cleaned them up a little with steel wool but they will come out better with some elbow grease and polish. $150
- Keihin pwk carbs with thumb throttle and cable. I measure them at just under 29mm (28.80) so not sure if just considerd the common 28's or 29mm? Choke knobs work good, no stripped screws. Cable seems good. thumb throttle cover is missing 1 screw $150
- Lonestar extended axle. some surface rust but axle is straight, good splines and threads. Comes with 2 1" spacers, stock locknuts. Measures 39" end to end. $125
- Complete rear brake system. Caliper, stock line, master cylinder lever and resi. Brakes worked, no leaks. Lever could use painted. $90
- Stock ignition coil good spark $20
- Kicker lever and knuckle still seems pretty tight. $20
- Left and right stock spindles. Straight with good threads $35
- Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included.
- Airbox with pro flow and KN Airbox has 1" hole on each side with screen, good lid and clamps. 1 damaged tab on box but mounts solid. K&N filter is well used but has some use left. Pro flow adapter in good shape. Intake boots included. $30
- Aluminum rear grab bar Not sure the brand straight and solid $20
- Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $25
- Rear brake hub and rotor Rotor straight hub looks good $20
- Stock front shocks 14" red springs, good shape not blown. $70
- Stock radiator no leaks, has a few fins flattend out here and there $15
Thats all ive had time to clean up and get boxed up for now. Hopefully this weekend i can get to the rest.
Frame looks good no cracks, needs paint or pc, the pegs are welded on , good engine cases, cylinders need a few studs helicoild i still need to measure bore, trans shifted good. Plastics are pretty rough, wheels and tires im keeping for my other one. good seat, Also have extended a arms not sure what brand .
heres a link to some of the pics i have as of now. Will get pics of the rest asap.
http://img94.imageshack.us/g/1048603j.jpg/
http://img94.imageshack.us/img94/4615/1048603j.jpg axle
http://img843.imageshack.us/img843/4134/1048605.jpg axle
http://img220.imageshack.us/img220/5531/1048594.jpg exhaust
http://img841.imageshack.us/img841/7192/1048596.jpg exhaust
http://img835.imageshack.us/img835/1504/1048568.jpg carbs
http://img560.imageshack.us/img560/1281/1048562.jpg carbs
http://img295.imageshack.us/img295/8738/1048561.jpg rear brakes
http://img840.imageshack.us/img840/7408/1048541.jpg kicker
http://img266.imageshack.us/img266/7409/1048623.jpg front shocks
http://img826.imageshack.us/img826/2623/1048627.jpg radiator
http://img269.imageshack.us/img269/3931/1048632.jpg grab bar
http://img198.imageshack.us/img198/9513/1048642.jpg airbox/pro flow
Edited by f4istunna
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
pm replied
Pro circuit pipes are sold
AK sorry i didnt get any pics yet ive been feeling like shit the past cpl days w/ a bad cold so havent been out in the garage . Ill get out there and take some pics asap though.
