  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
airbox sold thanks trick2stroke
Firemann the swinger is stock
not sure what brand a arms are sadly i stillhavent had a chance to get to the garage to get pics of them, i was pretty sick for a few days and been busy catching up w/ work since then. I still have to take 2 of them off the frame the bolts were seized i soaked them w/ pb so gonna go try and pull them off and get pics as soon as i can. no shorty levers sorry. has stock front lever and had a asv clutch lever but i used it on my Cr.
Bigblock im gonna email you a cpl bigger pics of the rad. heres the link to ebay auction (ill take it off and sell to you directly if you want it so can give you the better price ) http://cgi.ebay.com/ebaymotors/YAMAHA-BANSHEE-YFZ-350-STOCK-RADIATOR-COOLING-w-CAP-_W0QQcmdZViewItemQQhashZitem5add432df1QQitemZ390259224049QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
OK thanks, let me know when you get the details on the a-arms.
UPDATED LIST REDUCED PRICES. I have pics of all the parts just post or pm your email and ill send them. I tried a cpl times with image shack to upload the new ones i got and couldnt get to work.
- Lonestar extended axle. some surface rust but axle is straight, good splines and threads. Comes with 2 1" spacers, stock locknuts. Measures 39" end to end. $110
-Extended a arms standard travel beleive they are lonestar but not 100% sure they have heim joints straight and solid lowers are 16" fron center pivot to center bj stud uppers are 13" $150 black arms, chrome tie rods. Could use new paint or Pc
- Complete rear brake system. Caliper, stock line, master cylinder lever and resi. Brakes worked, no leaks. Lever could use painted. $80
- Stock ignition coil good spark $10
- Kicker lever and knuckle still seems pretty tight. $20
- Left and right stock spindles. Straight with good threads $30
- Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included.
- Aluminum rear grab bar Not sure the brand straight and solid $20
- Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $20
- Rear brake hub and rotor Rotor straight hub looks good $15
- Engine cases upper and lower. Upper great shape, lower has been repaired, no leaks good studs/threads. $75
- Stock radiator no leaks, has a few fins flattend out here and there $10
4 Mil crank with 2mm spacer plate for base of jugs looks to be vitos crank with short (110mm rds) (has Pc stamped on it) true and welded good shape $275
- stock stator w/ pickup works good $60
- stock rear shock $60
-wiring harness with stock cdi harness has a few ends cut off but main plugs are intact $40
- good kicker shaft with spring/bushing $5
- good shift shaft $5
-case saver with bolts $10
- Modquad head with 22cc domes, head has 2 bolt holes that will need repaired (prev. owner tried to put bigger bolts in jugs instead of helicoiling the right way and cracked the inside edge of 2 bolt holes. Easy fix for good alum welder fill and drill out. make offer
- Jugs 68mm will need a few studs repaired/helicoiled bores look good no scars or damage aside from normal wear, a crosshatch hone and should be ready to go. port/polish not sure what what type. make offer
- Lonestar antivibe stem with std. size lsr barclamps didnt have a stock stem to measure against i beleive this is +1 its 24" from center of steering/tierod flag to center of bar mount. chrome nice shape $130
- Stock frame straight and solid, has pegs welded to it and needs painted $50 pickup only
http://img94.imageshack.us/g/1048603j.jpg/
http://img94.imageshack.us/img94/4615/1048603j.jpg axle
http://img843.imageshack.us/img843/4134/1048605.jpg axle
http://img220.imageshack.us/img220/5531/1048594.jpg exhaust
http://img841.imageshack.us/img841/7192/1048596.jpg exhaust
http://img835.imageshack.us/img835/1504/1048568.jpg carbs
http://img560.imageshack.us/img560/1281/1048562.jpg carbs
http://img295.imageshack.us/img295/8738/1048561.jpg rear brakes
http://img840.imageshack.us/img840/7408/1048541.jpg kicker
http://img266.imageshack.us/img266/7409/1048623.jpg front shocks
http://img826.imageshack.us/img826/2623/1048627.jpg radiator
http://img269.imageshack.us/img269/3931/1048632.jpg grab bar
http://img198.imageshack.us/img198/9513/1048642.jpg airbox/pro flow
Edited by f4istunna
Ah no big deal man. I just didn't have the money at the time and still don't until some of my stuff sells. I was just hoping they would keep getting passed up until I had the cash lol. Anyway good luck with the rest and free bump too.
Ok heres what i have left to sell.
- Stock swingarm with axle carrier, bearings seem good could use painted or pc $35
- Rear brake hub and rotor Rotor straight hub looks good $10
- Engine cases upper and lower. Upper great shape, lower has been repaired, no leaks, good studs/threads. $75
- Stock gas tank with petcock and cap $15
- Complete clutch pack basket plates springs bolts ... $60
- stock shifter $5
- Jugs 68mm. they will need a few studs repaired/helicoiled bores look good no scars or damage aside from normal wear, a crosshatch hone and should be ready to go. they are port/polish . not sure what to ask so accepting offers....
- Stock frame straight and solid, has pegs welded to it and needs painted $50 local pickup only or will meet up within reasonable distance
- seat good pan, foam and latch, im prety sure the cover is in good shape too but i need to get in the garage attic and dbl check it to be sure ill get it down and smap some pics when i do.
  • 2 weeks later...
whats left prices cut....
Engine cases $50 upper good, lower has been repaired No leaks
kicker gear good $5
shift shaft $5
coil $10
spindles $30
rear wheel hubs $30
right side engine cover (clutch) $10
aluminum grab bar $20
font wheel hubs/rotors $20
rear brake hub and rotor $10
stock radiator $10
gas tank with cap/petcock $10
seat $25
If anyone is interested in taking it all off my hands id take $125 for everything + shipping
