crtscampbell Posted October 26, 2010 Report Posted October 26, 2010 I traded for a new bottom end with a hotrod 4mill in it. I put it together with wiseco 795M06550 pistons and the pistons past the top of the cylinder head at top dead center. They come up like a cm, just enough to tap the head. Is this normal for the 4 mills? Quote
hercalmighty Posted October 26, 2010 Report Posted October 26, 2010 Yes. The pistons will come out of the top of the cylinders about 2mm. You have to run cut domes or a spacer plate. The domes are the better way to do it. Quote
crtscampbell Posted October 26, 2010 Author Report Posted October 26, 2010 Yes. The pistons will come out of the top of the cylinders about 2mm. You have to run cut domes or a spacer plate. The domes are the better way to do it. Thanks, How do I run cut the domes? Quote
NYUK Posted October 26, 2010 Report Posted October 26, 2010 Thanks, How do I run cut the domes? i got 2 chariot heads for sale with domes cut for a 4 mil. call john 215 880 1990. Quote
jbooker82 Posted October 27, 2010 Report Posted October 27, 2010 You buy domes that are machined for a 4 mill crank, unless you have a lathe and the know how to cut them at the right angle. Quote
