Balzout Posted October 24, 2010 Report Posted October 24, 2010 If .030 is the minimum squish before the piston starts to kiss the head, would this hold true for the top ring also? How close can you run the ring to the top of the cylinder? Quote
rdzbangshee Posted October 24, 2010 Report Posted October 24, 2010 i run the vito's pistons the rings are custom cut 2mm lower to bring the heat away from the rings . Quote
Balzout Posted October 24, 2010 Author Report Posted October 24, 2010 Interesting. I'm new to the two strokes and thats something I've never dealt with. Is this common to do to positive deck height motors? Quote
Balzout Posted October 25, 2010 Author Report Posted October 25, 2010 Well lets try this one, since the pistons are up in the domes about .100, are the domes supposed to be cylinder diameter? Quote
stroking Posted October 26, 2010 Report Posted October 26, 2010 Well lets try this one, since the pistons are up in the domes about .100, are the domes supposed to be cylinder diameter? yes Quote
Balzout Posted October 28, 2010 Author Report Posted October 28, 2010 bump for how close can you run the top ring to the top of the cylinder? thanks Quote
AKheathen Posted October 29, 2010 Report Posted October 29, 2010 well, at 5mm, the ring pops out, usually. i'd have to say, you want to keep the ring 1.5 to 2mm down, but that's just looking at all the different setups i've seen Quote
