xXBlessedWithDeathXx Posted October 24, 2010 Report Posted October 24, 2010 From what i hear a lot of yous drag guys run them 4 bolt honda lonestar hubs so i figured i would post here. my question is what is the trick for the hub nuts so they dont hit the carrier when the the sprocket spins? i have a Boss carrier, is that the problem? this is my first roundhouse w / billet sprocket and rotor hub and its nothing but problems. i just dont get it. Quote
dajogejr Posted October 24, 2010 Report Posted October 24, 2010 Take a picture. The drag guys also run a 40mm aluminum axle as well. Let's see what you're talkin' about Willis. Quote
sleeper06 Posted October 24, 2010 Report Posted October 24, 2010 What are you talking about,axle/hub fitting.Do you have a new axle to or just a carrier?I have never had an issue and installed dozens of them im sure its just something simple you have been around for a lil Quote
xXBlessedWithDeathXx Posted October 24, 2010 Author Report Posted October 24, 2010 I have a few pics below. the pics below show that sprocket nuts hit the carrier. the nuts and bolts that i picked up are made for the honda sprocket / hub. i`m guessing i got the wrong parts. idk. i`m lost and any help will be appreciated. Quote
xXBlessedWithDeathXx Posted October 24, 2010 Author Report Posted October 24, 2010 What are you talking about,axle/hub fitting.Do you have a new axle to or just a carrier?I have never had an issue and installed dozens of them im sure its just something simple you have been around for a lil new lonestar axle / sprocket hub / rotor hub / boss carrier. the hubs fit on the axle but when its all bolted up the nuts on the back of the sprocket hub hit the carrier. Quote
STINKYDELUXE Posted October 24, 2010 Report Posted October 24, 2010 I have a similar problem Im planning on buying a JJ&A carrier if you look at theres it is smaller on the outside. Quote
xXBlessedWithDeathXx Posted October 24, 2010 Author Report Posted October 24, 2010 I`ll keep you post. i ordered a modquad carrier. if it dont work on that then you know not to get one. Quote
JKJK Posted October 24, 2010 Report Posted October 24, 2010 I had the same problem.Went to the local hardware store an purchased 4 grade 8 bolts with4 nylon lock nuts.Installed bolts reversed with nuts on the outside.Problem solved. Quote
xXBlessedWithDeathXx Posted October 25, 2010 Author Report Posted October 25, 2010 that could work but i got the right parts for the job and they dont work. after looking over what i have i noticed the nuts for the hub are the same thread as OEM axle hub nuts, so i twisted on of them on and it barely hits. i`m thinking that if i grind off the outer ring on the axle hub nuts it would work but then i`m left with 4 sprocket nuts that look like ass. i just think if they sell this shit they should tell you what to get or wtf to do when you get to this point. idk man. i`ll figure it out. i have a few pics below. OEM axle hub nut. Quote
xTHUNDERCATx Posted October 25, 2010 Report Posted October 25, 2010 (edited) this may sound dumb but may be worth trying, but on an actual honda its set up in reverse, the nuts are on the outside of the sprocket and the flush side of the bolt goes on the inside (closest to the carrier) if there would be a way to set it up like that it would fix it. but it seems odd they make everything else match the honda except the set up of the hub for the sprocket this is a picture of the one on my 250r Edited October 25, 2010 by xTHUNDERCATx Quote
xXBlessedWithDeathXx Posted October 25, 2010 Author Report Posted October 25, 2010 (edited) Thanks for that info. i`ll take measurements and post back after work. its worth a try. Edited October 25, 2010 by xXBlessedWithDeathXx Quote
xXBlessedWithDeathXx Posted October 25, 2010 Author Report Posted October 25, 2010 this may sound dumb but may be worth trying, but on an actual honda its set up in reverse, the nuts are on the outside of the sprocket and the flush side of the bolt goes on the inside (closest to the carrier) if there would be a way to set it up like that it would fix it. but it seems odd they make everything else match the honda except the set up of the hub for the sprocket this is a picture of the one on my 250r that dont work. Quote
Guest yuanyiw Posted October 26, 2010 Report Posted October 26, 2010 Wedding day is definitely a big occasion and the most special one. prom dresses Beautiful wedding photographs are very important to keep the wonderful memory of your wedding.prom dresses wedding dresses There you will need to know the some wedding photography tips. wedding dresses It is essential that you hire a professional photographer and give him or her all the details in advance, so that he can plan everything prior to the big day. wedding gowns Generally,wedding gowns brides and grooms do not understand the meaning of good photography. If this is the case, they will fail to get the desired results even when they hire the most expensive photographer of the town. Rather the wedding photographs should be as simple as possible, showing a picture of your perfect marriage ceremony. wedding dresses It is not the photographer alone but the bride,wedding dresses groom, all the guests, and the overall decoration of the venue will lead to having great wedding photography. Hence, both the parties, the photographer as well as the couple, are equally responsible for the wedding photographs. Quote
NickisGod Posted October 26, 2010 Report Posted October 26, 2010 I said this before to you, run the bolts that came with the sprocket so that allen head is facing the middle of the carrier. This worked for me and had no problems. Quote
xXBlessedWithDeathXx Posted October 26, 2010 Author Report Posted October 26, 2010 Thanks for them pics. thats what i`ll have to do. Quote
