Well I've been ridin my first banshee and it seems like when I punch it it goes pretty good but half way through the rpms jump,it spins the tires and takes off it does this through 123 gears and I haven't gotten it higher. It is .090 over cool head stage 2 reed valves piped and no air box on stock carbs are the carbs loading up or is this the "powerband" thanks
Ok thank you it kinda feels like an orgasm. what would putting the 35mm carbs do
The banshee powerband is unlike anyother ,,,, closest thing to the banshee band. was my 1996 cr 80 i had... I have yet to find a bike that hits as hard as a banshee when u crack that throttle..... Its an obsession!!!
If your engine isnt ported, i dont think bigger carbs will do much for you, 35s may even be too big, youd have to talk to someone who plays with big carbs, i build 60-70hp sleepers with stick carbs, so i'm not the right guy to ask...check and see if you have a timing advane, if nor get eother a plus 4 degree key or an adjustable timing plate, other than that, looks like you have a decent stock ripper, i would say porting is your next step...as far as the powerband kicking in, its fun isnt it ? Once you get used to it, you will just rev it and drop the clutch instead of feeling that bottom end bog and accelerate like no 4-stroke can dream of, hahaha
good luck with it man...
lol?
dude you gotta love that powerband its the shit!!!!! theres nothing else like it keep riding it will get you hooked like crack just gotta have more and more then more power welcome to the wonderful world two strokes
