fastquad02blaster Posted September 29, 2010 Report Posted September 29, 2010 Did he do a filter at some point and not rejet it? That's kindof what it is sounding like to me. You can tell by just looking at the plug if it's too rich or lean by the color. If they are black or dark brown it's too rich. A nice chocolate milk color is what you want. Quote
sp1tekiller Posted September 29, 2010 Author Report Posted September 29, 2010 Plugs looked dark brown, but not too bad. Borderline, maybe. Fresh gas, plugs and oil hasn't had any effect, at least just revving it. No room to run it right now. Going to purchase some jets and get cracking at it I guess. Quote
banshee67 Posted September 30, 2010 Report Posted September 30, 2010 Plugs looked dark brown, but not too bad. Borderline, maybe. Fresh gas, plugs and oil hasn't had any effect, at least just revving it. No room to run it right now. Going to purchase some jets and get cracking at it I guess. you have to run it before you know how it really runs. it runs slightly different when under a load. and you rip on it and make sure it is solid all the way through the rpms. no bogging and its not rapping way out when its not supposed to Quote
sp1tekiller Posted September 30, 2010 Author Report Posted September 30, 2010 Well he said it was bogging while riding it before, and also just revving the same way it is now. We'll double check, but I'm pretty sure nothings changed. Quote
zachass9 Posted September 30, 2010 Report Posted September 30, 2010 (edited) Make sure choke tub is between carbs, and make sure the filter is clean. Also check the condition of the reeds. I had a bike do this same thing, it ran great on bottom but wouldnt pull into the power at all. The wires in the stator cover were torn up! It was an easy fix, but involved a lot of headache because I chased fuel issues for ever, Just my .02, good luck!! Zac Edited September 30, 2010 by zachass9 Quote
sp1tekiller Posted September 30, 2010 Author Report Posted September 30, 2010 What the hell is a choke tub? Hahaha. Thanks for the input. Quote
sp1tekiller Posted September 30, 2010 Author Report Posted September 30, 2010 Oh, did you mean choke tube? How can I make sure he's got that on there? I don't really know what I'm looking for. Quote
GrMeyer Posted September 30, 2010 Report Posted September 30, 2010 Its a black tube that connects both carbs together. It is about 2-1/2 inch long. Its about half way up the carb on the inside. Quote
sp1tekiller Posted October 4, 2010 Author Report Posted October 4, 2010 Took it for a rip, definitely feels like the mains are too rich. Thanks for the all the input. Quote
sp1tekiller Posted October 7, 2010 Author Report Posted October 7, 2010 So he takes it to a trusted shop and they rejet it and proceed to call him and tell him that it's still running exactly the same. I'm not sure that this makes much sense, it seemed pretty clear that jetting was the problem. Assuming the jetting IS fine, what's the next issue we should chase? The stator? Reeds? Compression? Quote
EvilBanshee Posted October 8, 2010 Report Posted October 8, 2010 So he takes it to a trusted shop and they rejet it and proceed to call him and tell him that it's still running exactly the same. I'm not sure that this makes much sense, it seemed pretty clear that jetting was the problem. Assuming the jetting IS fine, what's the next issue we should chase? The stator? Reeds? Compression? I had a Similar problem. I put new Plug boots on and fixed the problem!! they couldnt deliver enough juice when i was reving er out with a load on it. In Neutral it would sound and run fine. But once i put a load on it,it would drop a cyclinder at higher RPM's. Quote
sp1tekiller Posted October 25, 2010 Author Report Posted October 25, 2010 A compression test revealed that there is only 90 in one side and 95 in the other. Obviously a top end is in order. I guess this could explain the bogging, eh? Quote
