bansheemann420 Posted September 20, 2010 Report Posted September 20, 2010 my pistons are a lil black on top what can i use to clean them up a lil bit??? firgured it would help Quote
Phelps Posted September 20, 2010 Report Posted September 20, 2010 waste up time unless the buildup is really thick... Quote
ECshee Posted September 20, 2010 Report Posted September 20, 2010 waste up time unless the buildup is really thick... meanwhile, for an actual answer...if you want to still go ahead and clean them for you own personal satisfaction.. try some contact cleaner, like carb cleaner or brake cleaner and wipe them clean with a clean rag. Quote
bansheemann420 Posted September 20, 2010 Author Report Posted September 20, 2010 meanwhile, for an actual answer...if you want to still go ahead and clean them for you own personal satisfaction.. try some contact cleaner, like carb cleaner or brake cleaner and wipe them clean with a clean rag. thanks guys its pretty caked on bad could i use a wire brush??? Quote
Larry's Shee Posted September 20, 2010 Report Posted September 20, 2010 I wouldn't use anything coarser than a scotch brite pad. Quote
bansheemann420 Posted September 21, 2010 Author Report Posted September 21, 2010 I wouldn't use anything coarser than a scotch brite pad. where could i get some????? Quote
#1JUANstunna Posted September 21, 2010 Report Posted September 21, 2010 Grocery store, Wal-Mart, Meijer or a store like that. Quote
