Im in the process of putting my banshee back together, just got it powder coated. I will do suspension later this winter. here where its at now.
My banshee is bored .60 over do i need to use a metal type gasket or just a oem type gasket for the base jugs and top. Also do I need to use any type of silicone on the gasket or just the gasket alone.
Thanks
You need to order a top end kit, and use the appropriate gasket for these 2 items. Do yourself a favour, and order 2 kits, that way if something gets screwed up during reassembly, you dont have to wait a week before you get your new set. If you put it back together perfectly the first time, thern you will have a spare second set for the next rebuild.
Thanks
you don't need silicone. make sure you torque it down right. check it again after break in.
Is Namura top end gasket kit any good? I seen it on ebay for under $14
Or Vito's top end gasket kit?
Thanks for the help!
