smzj4
Everything posted by smzj4
  1. I know I have the jet needles but i will have to look for the jets that came with them. I will find out on shipping to 09012 and send u a pm of total. Tomorrow sometime.
  2. These tires are in great shape. Not a lot of use on them. The rims have a few scrapes on the sides. They are visible in the pictures. About 1/2" long. Nothing bad as you can see. I would like $150 plus shipping. Will get shipping quote if serious about buying. http://s1179.photobucket.com/albums/x392/s_portrey/tires/
  3. T5 pipes, only 2 hours use. I bought these in the winter time thats why not much use. Sold Banshee with old pipes. So now selling these. $450 + shipping If a serious buyer will get a shipping quote. Excellent condition. Paid $630 including shipping...so this is a good deal for practically new pipes. My loss is your gain. http://i1179.photobucket.com/albums/x392/s_portrey/craigs002.jpg
  4. I have been trying to get a hold of him for over a week. With email and phone calls. Does anyone know if he's on vacation or what not?
  5. make sure you pull the gasket out of the bowl before setting the float height
  6. float height measurement should be 21mm
  7. you might try some 27.5 pilots
  8. It has oil of some sort happen to me to its easy to over look. Just sand it out and repaint should be good to go.
  9. What do you want done?
  10. Do some research on plug chop. the purpose of it is so that your not running to lean or rich .
  11. I live around the area i will let you know if i see a raptor like that. I know someone in marrionville who had his raptor stolen and set on fire a few months ago. I hate people like that.
  12. it was running but had fmf fattys on but not jetted correctly because when i hit the powerband in 4th gear it would just fall flat on its face.
  13. well i just got vforce 3 reeds and toomey t5's and wanted to know where i should be with my jetting. i thought that was what the form was for????
  14. anyone?
  15. 1) What type of aftermarket exhaust do you have?toomey t5s 2) What type of airfilter do you have?k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all?air box with lid but open to opinions 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )1374 5) What size pilot jets are you using?25 6) What size main jets are you using?280 7) What temperature is your Banshee jetted for?not sure 8) Do you have a port job? no 9) What kind of carbs?mikuni vm26ss 10) What size carbs?26 11) Additional information? bored 80 over,vforce 3 reeds, stock cross over tube, not sure if this matters needle jet is 345, also where should i start with the clip on the jet needle, what digit? Thanks
  16. Hey hq members, I had my frame powdercoated and need to know if the ignition coil unit grounds to the frame. Thanks
  17. http://www.cheapcycleparts.com/model_years/4630-yamaha-1994-banshee-YFZ350F/assemblies/134150 If you go to your yamaha dealer it will be the same part number
  18. I had the same thing happen. I thought it was leaking from the 2 bolts but coolant was running from the radiator joint. You need to pull the clutch basket and replace the rubber o-ring part number #16
  19. How do you post pictures, would like show you what it looked like.
  20. So I finally found that the seal was broke. Thanks for all your guys' help.
  21. Im in the process of taking the clutch cover off to check it out.
  22. I found the leak, its coming from the radiator hose joint that is by the water pump. Then its running down the drain hole in the middle of the case and running to the bolts.
  23. No, I wiped the two bolts with a rag and it started dripping right between the case an nut.
