SandShots Posted September 2, 2010 Report Posted September 2, 2010 wanted to know if I can get the lockout powder coated. not sure if atf affects it or not. Quote
jbooker82 Posted September 2, 2010 Report Posted September 2, 2010 I wouldnt do it. I would think the pc would make it stiff and less effective. If you want a colored lockup just find some one who does Anodizing. There are lots of people who do custom andodizing for Paint Ball Markers. Quote
SandShots Posted September 2, 2010 Author Report Posted September 2, 2010 I wouldnt do it. I would think the pc would make it stiff and less effective. If you want a colored lockup just find some one who does Anodizing. There are lots of people who do custom andodizing for Paint Ball Markers. i havent found anyone yet that will do it, all the shops around here are only willing to do large quantities at once. i guess my 3 items i have isnt worth my business, still looking around. any sponsors got a hookup for anodizing? Quote
jbooker82 Posted September 3, 2010 Report Posted September 3, 2010 i havent found anyone yet that will do it, all the shops around here are only willing to do large quantities at once. i guess my 3 items i have isnt worth my business, still looking around. any sponsors got a hookup for anodizing? The sponcers are going to be using a bulk anodizer. Where they have an alotment of parts done at once. That is why I said to look for a custom paint ball maker anodizer. You will need to tear it down so your just sending in the aluminum body http://gruntbullanodizing.com/index.html http://fbmfactory.com/fbmf/anodizing.html http://www.kohnsports.com/kohnlasering/anodizing.php http://aplusanodizing.com/ http://www.doropaintball.com/Anodizing.asp Quote
Vintage Smoke Posted September 3, 2010 Report Posted September 3, 2010 The sponcers are going to be using a bulk anodizer. Where they have an alotment of parts done at once. That is why I said to look for a custom paint ball maker anodizer. You will need to tear it down so your just sending in the aluminum body http://gruntbullanodizing.com/index.html http://fbmfactory.com/fbmf/anodizing.html http://www.kohnsports.com/kohnlasering/anodizing.php http://aplusanodizing.com/ http://www.doropaintball.com/Anodizing.asp Anodizing is usually done by the batch. Usually they dip a basket full of parts. It more or less gets priced by the basket load. They only want to do things in bulk. A paintball shop is a great idea. Piggyback on their order and I bet it will be cheap!! Quote
AKheathen Posted September 3, 2010 Report Posted September 3, 2010 maybe diamond dize it. that stuff is amazing. you can see it on youtube. i did my pressure plate instead, with engine enamel. no flaking or chipping yet, and if it does, it isn't going to chew up the tranny/gears. if you want to do the lockup in pc, have them mask off the finger channels, mount surfaces, and screw holes Quote
SandShots Posted September 4, 2010 Author Report Posted September 4, 2010 I wouldnt do it. I would think the pc would make it stiff and less effective. If you want a colored lockup just find some one who does Anodizing. There are lots of people who do custom andodizing for Paint Ball Markers. stiff? well i wouldnt do it on the weights or arms that open up, only on the body. Quote
SandShots Posted September 4, 2010 Author Report Posted September 4, 2010 maybe diamond dize it. that stuff is amazing. you can see it on youtube. i did my pressure plate instead, with engine enamel. no flaking or chipping yet, and if it does, it isn't going to chew up the tranny/gears. if you want to do the lockup in pc, have them mask off the finger channels, mount surfaces, and screw holes good job man, looks good. i sent the stuff out, gimme about a wk, so i can get it back after the holiday weekend and i'll snap some pix to share . Quote
Koolguyson Posted September 4, 2010 Report Posted September 4, 2010 Every anodizer has a "minimum" charge. They'll do any quantity you want, but they won't give you a discount for a single part. I anodized mine and the clearances were fine. However, if you PC it, I doubt the arm to body clearance will be ok. If you DO PC it, ask the PC'er to tape off the sections that are tolerance specific. Quote
jbooker82 Posted September 4, 2010 Report Posted September 4, 2010 stiff? well i wouldnt do it on the weights or arms that open up, only on the body. Yea if you get PC in the finger channels or the small channles where the weight pins run. The pc would cause the weights to hang up and not move freely. Quote
