ballsdeep Posted August 28, 2010 Report Posted August 28, 2010 i'm relatively new to the banshee scene. im currently deployed to afghanistan but when i went home for R&R i was lucky enough to find a 2003 banshee in amazing shape for $2500. the bike is a beast but like anyone i wanna make it faster. i see people talking about boring out 4mm and so on. what exactly does that mean, how is it done? Quote
Koolguyson Posted August 28, 2010 Report Posted August 28, 2010 i'm relatively new to the banshee scene. im currently deployed to afghanistan but when i went home for R&R i was lucky enough to find a 2003 banshee in amazing shape for $2500. the bike is a beast but like anyone i wanna make it faster. i see people talking about boring out 4mm and so on. what exactly does that mean, how is it done? Boring a motor is often more detrimental than leaving it the way it is. Without getting too technical, the larger the bore, the smaller the cylinder transfer area. Not a considerable loss in performance, but it is worth noting and definitely not worth bragging about. If anything I would stay away from a motor like this because if you do hurt a piston...chances are you can't bore it to fix it. A 4mm/7mm/10mm/etc is referring to the overall travel that the piston moves up and down. By increasing the stroke of a motor you can greatly increase the performance of the motor. Quote
ballsdeep Posted August 28, 2010 Author Report Posted August 28, 2010 Boring a motor is often more detrimental than leaving it the way it is. Without getting too technical, the larger the bore, the smaller the cylinder transfer area. Not a considerable loss in performance, but it is worth noting and definitely not worth bragging about. If anything I would stay away from a motor like this because if you do hurt a piston...chances are you can't bore it to fix it. A 4mm/7mm/10mm/etc is referring to the overall travel that the piston moves up and down. By increasing the stroke of a motor you can greatly increase the performance of the motor. thanks! i feel smarter already Quote
dirtydownunder Posted August 29, 2010 Report Posted August 29, 2010 wats done to it now ? if its stock, some pipes, timing plate, cool head with smaller dome and air cleaner setup will give noticeable gains. if thats already done, porting will wake her up. theres always something to do to a banshee to make it faster. Quote
ballsdeep Posted August 29, 2010 Author Report Posted August 29, 2010 wats done to it now ? if its stock, some pipes, timing plate, cool head with smaller dome and air cleaner setup will give noticeable gains. if thats already done, porting will wake her up. theres always something to do to a banshee to make it faster. as far as i know its only upgrade is the the exhauste.. im a full CPI exhaust. alot of people are telling me to switch toomey, but i like the way it looks and sounds already plus im not trying to be like everybody else! what is porting? Quote
06specialedition Posted August 29, 2010 Report Posted August 29, 2010 If you have all your major bolt ons like, pipes, reeds, cool head, timing plate..etc. You can get it ported and will make a huge differance. I had Brandon @ Wildcard Racing do mine and he is a site sponsor on here Quote
Pasi S. Posted August 29, 2010 Report Posted August 29, 2010 as far as i know its only upgrade is the the exhauste.. im a full CPI exhaust. alot of people are telling me to switch toomey, but i like the way it looks and sounds already plus im not trying to be like everybody else! what is porting? Porting is when you change the size, duration, shape and angles in your intake, transfer and exhaust ports in your cylinder. This way you can modify the power output in your motor. Porting is something that should always be done by professional builder. ...something like that. -Pasi S. Quote
RagunCajun Posted August 30, 2010 Report Posted August 30, 2010 You dont bore out a 2 stroke to make it faster. You only bore out usually to repair a harmed cylinder. I hear that all the time from ignorant 4 stroke people. CPI's are good pipes. Very high in demand and can offer some good money if you chose to get rid of them. They arent really best for non ported engines. However, they will work fine. And if you never had much time on a bike with anything else, you probably wont notice the difference. The pipes(along with other factors but pipes are very important) determine how the powerband acts. CPI's are more of an inframe drag pipe. They will rev higher than toomey's but come on(by come on i mean when the powerband hits) a little later in the rpm range. Before you start ordering all sorts of goodies, just take time to get acquired with your new machine. Enjoy it, make sure all your fluids are ok. Check for loose screws etc. You can learn a lot from these forums but anything you have questions about feel free to ask. Sometimes, people might unwillingly give you false info. But that's on any forum. Luckly, one of us will steer you right. Now on to porting. It's one of the best mods for your money you can do. There's many companies who do it. Some people including myself chose to swing from a builders nuts due to satisfaction of their work etc. Research and go from there. Again, enjoy the bike as is before tearing it down to get the cylinders ported. Welcome to HQ and thank you VERY much for serving our country! Quote
midlifecrisis Posted September 1, 2010 Report Posted September 1, 2010 Everything Rajun said, and I mean everything! Quote
ballsdeep Posted September 1, 2010 Author Report Posted September 1, 2010 Thanks i appreciate all the help, and im glad to serve! RagunCajun where in Louisiana are you located. im from Lafayette. and besides forest hills is there anywhere else good to ride Quote
Hilarious Posted September 1, 2010 Report Posted September 1, 2010 Thanks i appreciate all the help, and im glad to serve! RagunCajun where in Louisiana are you located. im from Lafayette. and besides forest hills is there anywhere else good to ride That would be the la dunes. Come on over to ms at sandhillatv near wiggins. I am not sure how far out you are but i know there are a lot of la people that we ride with. Its well worth a trip out. Quote
ballsdeep Posted September 1, 2010 Author Report Posted September 1, 2010 That would be the la dunes. Come on over to ms at sandhillatv near wiggins. I am not sure how far out you are but i know there are a lot of la people that we ride with. Its well worth a trip out. [/quow actually i live in Gulfport most of the time when i am home on leave. im from LA but the past two years i've been in Germany and now im here in Afghanistan. ill be back around june so ill definitly make that trip Quote
Hilarious Posted September 2, 2010 Report Posted September 2, 2010 actually i live in Gulfport most of the time when i am home on leave. im from LA but the past two years i've been in Germany and now im here in Afghanistan. ill be back around june so ill definitly make that trip you are about 30~40 minutes out then. be safe and get home in one piece. Quote
