Banshee420John Posted August 23, 2010 Report Posted August 23, 2010 Hey guys i just picked up a 2001 banshee and was wandering if i just put straight gas in it and 2 stroke oil somewhere else or i have to mix? if i have to mix how much oil do i put in a five gallon jerry can. thanks Quote
bbcmudtruck Posted August 23, 2010 Report Posted August 23, 2010 Mix it in your gas can before you put it in the bike. I mix mine at 40:1 because it does an even 10 gallons. Quote
12 0 Clock P I M P Posted August 23, 2010 Report Posted August 23, 2010 Mix it in your gas can before you put it in the bike. I mix mine at 40:1 because it does an even 10 gallons. Yes you must PRE MIX the fuel with the oil....... Everyone runs different ratios.....I run 38:1 or close to it.....40:1 somewhere in that area will be fine Quote
06specialedition Posted August 23, 2010 Report Posted August 23, 2010 Mix it in a gas can. 40:1 with premium gas Quote
muggzy Posted August 23, 2010 Report Posted August 23, 2010 Get high quality synthetic or synthetic blend 2-cycle oil. Not the shit off of Walmart's shelves. Until you know what you're working with, be safe and mix your oil at 32:1 (4ozs/gal) Quote
Banshee420John Posted August 25, 2010 Author Report Posted August 25, 2010 thanks guys, i just traded my lifted jeep for it and asked every other question except for......... can i run vp race fuel on a next to stock machine? it has fmf fatty pipes boysen reeds, jetting and a slight over bore, not sure what size over bore but im guessing the next size up. Quote
Jereme6655 Posted August 25, 2010 Report Posted August 25, 2010 thanks guys, i just traded my lifted jeep for it and asked every other question except for......... can i run vp race fuel on a next to stock machine? it has fmf fatty pipes boysen reeds, jetting and a slight over bore, not sure what size over bore but im guessing the next size up. on a almost stock motor running race fuel will actually bring down your preformance. Not sure what you know about fuels so don 't freak out if you already know this.....but higher octane fuel actually has a more controlled SLOWER burn. You don't need to run race fuel unless your compression is really high. and No.....running a high octane fuel does not make your quad run faster. Quote
Banshee420John Posted August 25, 2010 Author Report Posted August 25, 2010 (edited) cool, i just thought id ask cuz i have a couple gallons of VP left from my jeep (4.7l stroker) it was high comp running 40. over chev pistons and 2.02 ls1 intake and 1.60 exhaust ls1 valves and ran like shit on pump gas, i am just premixing with premium. maybe next spring ill have a high comp stroker in my banshee, just had it for a couple days and am already wanting more power, not that it doesnt already have some. more is always better. Edited August 25, 2010 by Banshee420John Quote
jacquesraney Posted August 26, 2010 Report Posted August 26, 2010 cool, i just thought id ask cuz i have a couple gallons of VP left from my jeep (4.7l stroker) it was high comp running 40. over chev pistons and 2.02 ls1 intake and 1.60 exhaust ls1 valves and ran like shit on pump gas, i am just premixing with premium. maybe next spring ill have a high comp stroker in my banshee, just had it for a couple days and am already wanting more power, not that it doesnt already have some. more is always better. I smell a blown engine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote
Banshee420John Posted August 26, 2010 Author Report Posted August 26, 2010 I smell a blown engine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! is running premium in my banshee a bad thing? Quote
