bansheesandrider Posted July 16, 2010 Report Share Posted July 16, 2010 The tors system has a rev limiter built into it that is how it limits the motor when the tors is activated. This is why simply unhooking the tors control box will fix a limited motor from a faulty tors which is very common. The only way to 100% guarantee a grounded out motor is to ground the coil directly. In case of a CDI failure the motor could possibly not shut down with simply grounding out the wire threw the cdi. That is why we always ground out the coil to guarantee a good kill. I know what the instructions say that come with the kill switches but we have installed hundreds of tethers this way and not one cdi failure. The TORS system does not limit RPM, when it is activated it shuts down the ignition system completely. If you have a CDI box failure the bike is not going to run anyway so there is no need to shut it down. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted July 17, 2010 Report Share Posted July 17, 2010 (edited) that isn't a rev limiter, rev limiters dont come with a on/off switch, it is either there or not. that is more a fail safe mode. just like TORS is a fail safe device. a rev limiter is when the engine hits a certain RPM, the computer will cut either fuel, ignition or both. It is a rev limiter because it cuts out spark when the PB is set and the bike will only rev to about 1/4 or 1/3 of its maximum RPM. It does not shut off the spark completely like the TORS system does, it limits RPM. It is called a Park Brake Rev LImiter in the factory Yamaha service manual. Edited July 17, 2010 by bansheesandrider 1 Quote Link to comment Share on other sites More sharing options...
shawn941 Posted July 17, 2010 Report Share Posted July 17, 2010 The tors system has a rev limiter built into it that is how it limits the motor when the tors is activated. This is why simply unhooking the tors control box will fix a limited motor from a faulty tors which is very common. The only way to 100% guarantee a grounded out motor is to ground the coil directly. In case of a CDI failure the motor could possibly not shut down with simply grounding out the wire threw the cdi. That is why we always ground out the coil to guarantee a good kill. I know what the instructions say that come with the kill switches but we have installed hundreds of tethers this way and not one cdi failure. the instructions that came with my prodesign is exactly how you guys, and my self wire tethers Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted July 17, 2010 Report Share Posted July 17, 2010 I deleted my key switch because it was pointless. While i was doing that i installed my pro design tether kill switch. Very simple as i just fallowed the instructions. I also took the on/off/light switch and shoved it behind the radiator to clean up the bars. http://s240.photobucket.com/albums/ff111/raguncajun/?action=view¤t=banshee25-18-09.jpg Quote Link to comment Share on other sites More sharing options...
