Slammin Full Bore Posted July 9, 2010 Report Posted July 9, 2010 Hi All. My bike has been sitting for two years up on two wheels. I know big mistake. The carbs shot fuel out of the overflow when I turned the gas on. do I need to rebuild these? If so, what do I need to rebuild it.They are stock carbs but jetted. Just want to make sure I buy all the right stuff online today. Thanks a bunch! -Ryan Quote
Larry's Shee Posted July 10, 2010 Report Posted July 10, 2010 You might want to start with a good cleaning. Probably residue from the fuel evaporating leaving gunky oil and varnish. Might get away with just float valve and seat. Check with the site sponsers , they probably have them. Quote
GrMeyer Posted July 10, 2010 Report Posted July 10, 2010 most of the time you can get away with float needle and seat. Quote
AKheathen Posted July 10, 2010 Report Posted July 10, 2010 give them a good cleaning, 1 AT A TIME, and make sure they are adjusted right. if they still leak, then get both float neeld/seats, and bowl gaskets. Quote
