my clutch lever has no pressure and the basket doesnt move I have a feeling that its something minor but i cant put my hand on it this is the only thing keeping me from ridin my bike please help guys any info would be a blessing thanks.
You probably broke the clutch cable, or you have stretched the cable out, and need to adjust it at the perch. Try checking those two out, and let us know.
Edited by fastbanshee8
Look at your downshaft as you pull in on the clutch handle. If this done not move, then your pushrod probably slipped passed your downshaft. Depending on how badly the pushrod is mushroomed you may have to split the cases in order to get it out properly.
so you can pull the clutch lever in, but the clutch doesn't move? did you replace the clutch recently? maybe you forgot to put the metal ball back in like i did?
maybe you need to adjust the clutch from the inside too.
i did forget to put the metal ball back in but i put it in a still nothing
The pressure plate can be put on in a way that it doesn't drop down over the clutch pack. There is a punched mark on the inner clutch boss and an arrow mark on the pressure plate. Make sure you have them lined up correctly.
