Alright everyone I have a 1999 Shee that I bought blown up and have rebuilt and mildly built myself. I use it in the ATV rodeos and do fairly well, but I am looking to do better in the drags and not hurt myself in the events too badly.... Here is what I have done to the bike so far...
- Bored .30 over with Wiesco Prolite's
- K&N With Proflo Intake and NO Airbox Lid and hole drilled into the airbox ( I did not do this the bike already had the holes drilled into it when I got it... Will this hurt it?)
- Jetted For Toomey T5's and K&N
- TOR's Removal Kit
- Lowerd with 250ex Stock shocks
- 12 Tooth Sprocket on the Front and Stock Sprocket Gearing on the back.
- Holeshot 18"s on the front Kenda Klaw 18"s on the Back
- I plan on Porting and Polishing but dont know exactly what I should get MIld Drag?, I would do Full Drag Port but I've been told if you miss shift you will just fall on you're face.
- And I also plan for a Cool Head or Mod Quad Head (Which is better and what size domes should I get?)
Now thing's I should do?
-Reeds?
-Carbs?
- Give me some Ideas
I'm all for anything as long as I wont need to stretch it.
Thanks for any advice guys.
get a set of 4-snow, or pro-wedge tires. get some V-Force II reeds. go to a 34-35mm carb. that is what i would change for a drag only setup that is.. and idk either what an ATV rodeo is.
An ATV Rodeo is a series of event such as horses do where you set up three barrels and race around them for the quickest time. There are 5 different events each rodeo and drag races at the end I just don't want to goo so radical that I have to stretch the bike to hold it down and the handling is not affected.
Also I have a set of 4-snows thank you for the advice...
Edited by Lokie
Or even the 14 tooth, with having only 18" rears, because the smaller rear tires are already gearing it down.
I would gear it back up but our drags aren't even 300 ft, There is only one and by the end of it I'm still pulling hard. But I may try it out one weekend.
  • 2 weeks later...
The 12t Front sprocket?? that may be a little tight for the chain to wrap around. I think you should be good with a 13t, you can also mess with the rear sprocket for more of gear tuning.
Which rodeos do you go to around here?
Roby and Lebanon usually... What one's do you go too?
I go to Roby and sometimes Lebanon. Plus some other random ones here and there. I have a yellow/black raptor and a blue banshee I rodeo with.
Jake right? Yah I remember that beast lol.... I ride the black and red banshee withe the Monster Graphics... We've dragged a couple times at Roby.
