Jaystre Posted June 25, 2010 Report Posted June 25, 2010 i am about to put my top end back together just received the kit today and my head gasket that was on before seems way thicker than the one i received is this normal ? Quote
lt1bird Posted June 25, 2010 Report Posted June 25, 2010 Could be flatend out a bit...best to measure it with some calipers... Quote
Jaystre Posted June 26, 2010 Author Report Posted June 26, 2010 yeah but my old one is like three gaskets in one can i reuse it if its not damaged Quote
BellicoseBanshee Posted June 26, 2010 Report Posted June 26, 2010 yeah but my old one is like three gaskets in one can i reuse it if its not damaged I wonder if the old one you have is the thick one some people use with a 4mm crank and no spacer plate. I would not reuse a head gasket... Quote
Jaystre Posted June 26, 2010 Author Report Posted June 26, 2010 I wonder if the old one you have is the thick one some people use with a 4mm crank and no spacer plate. I would not reuse a head gasket... that could be right i have a 4 mm crank and a pro design cool head. but i ordered the wiseco top end kit with gaskets piston etc why wouldnt i get the same gasket Quote
BellicoseBanshee Posted June 26, 2010 Report Posted June 26, 2010 Do you have recessed domes? With a Cool Head and a 4mm crank, you should be using recessed domes. The 795 series pistons are used with a long rod, but the pistons will stick up 2mm when a 4mm crank is used. That is why the domes are recessed, or the spacer plate is used, or the thicker gasket set-up is used (stock head). Quote
Jaystre Posted June 27, 2010 Author Report Posted June 27, 2010 i have 21 cc domes but as far as recessed im not sure Quote
AKheathen Posted June 27, 2010 Report Posted June 27, 2010 is it a multi-layer metal gasket, or solid spacer, about 1.5mm thick? coolheads don't use gaskets, just o-rings to seal, but if your domes aren't recessed, you need it spaced to clear the crank. to tell if the domes are recessed, compare the edge of the squish band in the chamber to the o-ring recess. if it's about the same depth as the o-ring, then it's a regular stock stroke dome. if it's allot deeper, like more than 1mm, then it's a recessed dome. coper gaskets, and even aluminum spacers are reuseable, just clean them good and re-seal with coper gasket spray, or whatever was there when you took it off. take some squish measurements when you get it back together Quote
Jaystre Posted June 27, 2010 Author Report Posted June 27, 2010 is it a multi-layer metal gasket, or solid spacer, about 1.5mm thick? coolheads don't use gaskets, just o-rings to seal, but if your domes aren't recessed, you need it spaced to clear the crank. to tell if the domes are recessed, compare the edge of the squish band in the chamber to the o-ring recess. if it's about the same depth as the o-ring, then it's a regular stock stroke dome. if it's allot deeper, like more than 1mm, then it's a recessed dome. coper gaskets, and even aluminum spacers are reuseable, just clean them good and re-seal with coper gasket spray, or whatever was there when you took it off. take some squish measurements when you get it back together yeah its a multi layer metal gasket and its about 2mm thick i guess if it was on it before it will be needed again but i will try to see if its recessed Quote
Jaystre Posted June 27, 2010 Author Report Posted June 27, 2010 i measured from the highest point on the underneath of the dome and in the o-ring recess i have 1.5mm and on the other side it is 0.7mm so my guess (correct me if im wrong ) is that its a stock stroke dome . And about squish measurement how do u go about doing that ? im quite new at this so thats why ive been asking so many questions just want to get it done right Quote
shawn941 Posted June 27, 2010 Report Posted June 27, 2010 i measured from the highest point on the underneath of the dome and in the o-ring recess i have 1.5mm and on the other side it is 0.7mm so my guess (correct me if im wrong ) is that its a stock stroke dome . And about squish measurement how do u go about doing that ? im quite new at this so thats why ive been asking so many questions just want to get it done right take a piece 0.60 solder,bend it at the end and put it inside a plug hole and crank bike over once so the piston hits the solder one time,,,then mic it. you dont wanna be under .040. make sure and do both sides.... Quote
AKheathen Posted June 27, 2010 Report Posted June 27, 2010 make sure to line it up with the wristpin from right to left Quote
jan1213 Posted June 29, 2010 Report Posted June 29, 2010 Recommending Zhuge Liang on Horseback World of Warcraft power leveling, Xu Shu was much valued by Liu Bei for his strategic talents.World of Warcraft power leveling After several victories on the battleground against Cao Cao, Xu was made the chief military advisor. At the news, Cao Cao was begrudging. “If you want this person,” one of his advisors said, “you can bring his mother to Xuchang and send a forged letter in his mother's handwriting, asking Xu Shu to desert Liu Bei and come here. As Xu is well-known for a strong filial affection, surely he will come.” This plot worked, for Xu, on receiving the letter, cried tearfully, asking Liu Bei for an immediate departure. Feeling sad, though, Liu persisted in his stay for another night, during which the two aired their sad feelings. last chaos gold, the next day Liu laid a banquet outside the city for Xu.last chaos gold Holding the latter's hand, Liu said, “After we separate today, only heaven knows when and where we will meet again.” He wept bitter tears. After setting off on his way, Xu suddenly turned his horse and returned. “I almost forgot an important matter,” he said to Liu. “Ten kilometers from Xiangyang City, in a place called Long zhong, Do you want to meet him?” Liu expressed his willingness at once, but also aired doubt about whether Zhuge Liang was as talented as Xu. aoc power leveling, “He tells configurations of stars in the heavens,aoc power leveling” Xu assured him, “and recognizes everything on earth. He knows a person's real nature at the first meeting-the number one talent under the heaven. If you have him as your military advisor, you'll have the country under your name.” Liu suggested a visit to Zhuge by Xu on his behalf, at this, the latter shook his head in disapproval. “You must go and offer your invitation personally, and his acceptance depends entirely on your sincerity.” With these words said, Xu turned his horse and left. Later, Liu paid three trips to Zhuge's straw house, another favorite story among Chinese people. aoc power leveling, This is a story from Three Kingdoms.aoc power leveling Zhang Lu ordered Ma Chao to attack Jiameng Pass. Learning this, Liu Bei immediately went to his military advisor Zhuge Liang for ideas. Zhuge Liang said, “Mao Chao is so brave that only Zhang Fei and Zhao Yun can match him. But Zhang Fei and Zhao Yun can match him. But Zhao Yun is not available; only Zhang Fei is around at the moment.” Final Fantasy XI GIL, Knowing that Ma Chao was attacking the pass,Final Fantasy XI GIL Zhang Fei came to ask for a fight against him. Pretending not to hear, Zhuge Liang said to Liu Bei, “Ma Chao is attacking, and only Zhao Yun can defeat him.” Feeling snubbed, Zhang Fei noted his past merits and shouted, “If I can not defeat Ma Chao, I am willing to be punished according the rule.” Only then did Zhuge Liang nod his aGREement. Liu Bei himself acted as the chief commander and ordered Zhang Fei to fight in the vanguard. Liu Bei led the army to the pass. Time and again Ma Chao challenged them to fight. At every challenge, Zhang Fei wanted to engage him, but was stopped by Liu Bei. When Liu Bei saw Ma Chao and his army became fatigued, he ordered Zhang Fei to take on the challenge. aion kinah, Zhang Fei and Ma Chao fought one hundred rounds with an even hand.aion kinah When Liu Bei saw that it was turning dark, he asked Zhang Fei to come back for a fight tomorrow. But Zhang Fei became infuriated and shouted, “Light more torches and get ready for a night fight. I will not return to the pass without defeating Ma Chao!” Ma Chao also pledged that he would not return to his camp without winning over Zhang Fei. Each of them mounted fresh horses to start the night fight. After another twenty rounds, Ma Chao saw that he could not win by force, so he had an idea. He pretended to flee. At the moment, Zhuge Liang arrived. He analyzed Ma Chao's situation and laid a trap for him. With Ma Chao in a fight spot, Zhuge Liang sent someone who succeeded in persuading him to fight for Liu Bei. Quote
AKheathen Posted June 29, 2010 Report Posted June 29, 2010 Recommending Zhuge Liang on Horseback World of Warcraft power leveling, Xu Shu was much valued by Liu Bei for his strategic talents.World of Warcraft power leveling After several victories on the battleground against Cao Cao, Xu was made the chief military advisor. At the news, Cao Cao was begrudging. “If you want this person,” one of his advisors said, “you can bring his mother to Xuchang and send a forged letter in his mother's handwriting, asking Xu Shu to desert Liu Bei and come here. As Xu is well-known for a strong filial affection, surely he will come.” This plot worked, for Xu, on receiving the letter, cried tearfully, asking Liu Bei for an immediate departure. Feeling sad, though, Liu persisted in his stay for another night, during which the two aired their sad feelings. last chaos gold, the next day Liu laid a banquet outside the city for Xu.last chaos gold Holding the latter's hand, Liu said, “After we separate today, only heaven knows when and where we will meet again.” He wept bitter tears. After setting off on his way, Xu suddenly turned his horse and returned. “I almost forgot an important matter,” he said to Liu. “Ten kilometers from Xiangyang City, in a place called Long zhong, Do you want to meet him?” Liu expressed his willingness at once, but also aired doubt about whether Zhuge Liang was as talented as Xu. aoc power leveling, “He tells configurations of stars in the heavens,aoc power leveling” Xu assured him, “and recognizes everything on earth. He knows a person's real nature at the first meeting-the number one talent under the heaven. If you have him as your military advisor, you'll have the country under your name.” Liu suggested a visit to Zhuge by Xu on his behalf, at this, the latter shook his head in disapproval. “You must go and offer your invitation personally, and his acceptance depends entirely on your sincerity.” With these words said, Xu turned his horse and left. Later, Liu paid three trips to Zhuge's straw house, another favorite story among Chinese people. aoc power leveling, This is a story from Three Kingdoms.aoc power leveling Zhang Lu ordered Ma Chao to attack Jiameng Pass. Learning this, Liu Bei immediately went to his military advisor Zhuge Liang for ideas. Zhuge Liang said, “Mao Chao is so brave that only Zhang Fei and Zhao Yun can match him. But Zhang Fei and Zhao Yun can match him. But Zhao Yun is not available; only Zhang Fei is around at the moment.” Final Fantasy XI GIL, Knowing that Ma Chao was attacking the pass,Final Fantasy XI GIL Zhang Fei came to ask for a fight against him. Pretending not to hear, Zhuge Liang said to Liu Bei, “Ma Chao is attacking, and only Zhao Yun can defeat him.” Feeling snubbed, Zhang Fei noted his past merits and shouted, “If I can not defeat Ma Chao, I am willing to be punished according the rule.” Only then did Zhuge Liang nod his aGREement. Liu Bei himself acted as the chief commander and ordered Zhang Fei to fight in the vanguard. Liu Bei led the army to the pass. Time and again Ma Chao challenged them to fight. At every challenge, Zhang Fei wanted to engage him, but was stopped by Liu Bei. When Liu Bei saw Ma Chao and his army became fatigued, he ordered Zhang Fei to take on the challenge. aion kinah, Zhang Fei and Ma Chao fought one hundred rounds with an even hand.aion kinah When Liu Bei saw that it was turning dark, he asked Zhang Fei to come back for a fight tomorrow. But Zhang Fei became infuriated and shouted, “Light more torches and get ready for a night fight. I will not return to the pass without defeating Ma Chao!” Ma Chao also pledged that he would not return to his camp without winning over Zhang Fei. Each of them mounted fresh horses to start the night fight. After another twenty rounds, Ma Chao saw that he could not win by force, so he had an idea. He pretended to flee. At the moment, Zhuge Liang arrived. He analyzed Ma Chao's situation and laid a trap for him. With Ma Chao in a fight spot, Zhuge Liang sent someone who succeeded in persuading him to fight for Liu Bei. wtf is that rpg shit? i'm sure it belongs in a comp/tech, or off-topic section thread...... Quote
