Its just wore out you can pick one up at cycle world or petes cycle they're less then $20 I believe. I replaced mine like a year ago.
banshee choke wont stay out all the way and wont sit on the half way notch anyone help??????
mine did the same thing so what i did was take a small zip tie and went around the brass part and made it tight enough so that i could pull the choke out and slide it over the brass to the carb and it will hold it out
lol, mine kinda worked when it was cold, since the rubber was stiff enough to hold some. the way i saw it, though, was that when the little metal clip wears out under the rubber boot, the seals and shaft/body are probably worn out, too, so i just replaced it, rather than make a new wire clip.
