Like I told you the other day.. This is from Andy at M&M..
Ok let me rephrase that you cannot override into 5th on a downshiftable tranny and still have 6th. You can start in 2nd on the 1-5 or i can cut it how ever you want. Level 2 is undercutting the engaging dogs so higher hp machines will hold together. If its for your setup i would def recommend it. All i stock is the undercut its just a better tranny imo. I tell people that 100 hp is where i really try and push the undercut.
Ya ya I know what you said. However there are people that are running them. I really need a 2-5, but I would like to keep 6th.
Who do you know that has an override that's either a 1-5 or 2-5 that still has 6th gear? Shannon's extreme has no 6th.
Haha, well actually I was under the impression that his still had 6th. I thought that if you kept nuetral in the stock location, you could have a 2-5 with a manual 6th.
Do you remember looking at his tranny at all? Remember the spacer that was in there? That's where 6th gear goes.
Hey Ryan, i have the 1-4 Dunable w/ stock nuetral and m5th and m6th in stock. Isnt that what your wanting?
perhaps a n-down 1-5 duneable with 15/41 gearing would be better. at least 20" rear tires would be a must though.
Only reason i wouldnt want anything with a manual(clutch) last gear or two is forgetting what gear you are in. With all of them clutchless you can just upshift till it wont shift up anymore. But for a lot of 55-60+ mph riding id want 6th. I went play around yesterday on my 19" holeshots and not having 6th sucked big time!
Edited by RagunCajun
