CadyRidah Posted June 17, 2010 Report Posted June 17, 2010 Anyone know what's wrong with this Banshee? It starts up but on the right side the exhaust pressure is normal and on the left side barely any pressure comes out. It's like it's barely running. Anyone know what might be the problem? Quote
lilmegill727 Posted June 17, 2010 Report Posted June 17, 2010 low compression on the one side, or even an air leak. Quote
CadyRidah Posted June 17, 2010 Author Report Posted June 17, 2010 low compression on the one side, or even an air leak. You might be right about the low compression. I didn't notice an air leak. The boots look fine too but I'll check them again. Quote
So Cal Suspension Posted June 17, 2010 Report Posted June 17, 2010 You might be right about the low compression. I didn't notice an air leak. The boots look fine too but I'll check them again. Check the reeds on the low side, also. Quote
pr0blumz Posted June 17, 2010 Report Posted June 17, 2010 The above things mentioned and the reeds as well could cause that problem. Quote
TeamRealtreeHD Posted June 17, 2010 Report Posted June 17, 2010 I had this problem... it turned out to be a reed petal was damaged. All good info above. Check everything. Compression test, rip the intakes off and check the reeds, etc. Quote
fastbanshee8 Posted June 17, 2010 Report Posted June 17, 2010 I had the same problem a little more than a month ago, and it ended up being a bad coil. It would only fire both sides, when the coil was cold, and as soon as it got warmed up, the left side would quit. Quote
CadyRidah Posted June 17, 2010 Author Report Posted June 17, 2010 (edited) I had the same problem a little more than a month ago, and it ended up being a bad coil. It would only fire both sides, when the coil was cold, and as soon as it got warmed up, the left side would quit. How much did the coil cost you? Edited June 17, 2010 by CadyRidah Quote
CadyRidah Posted June 17, 2010 Author Report Posted June 17, 2010 Ok it's not the coil. I did notice that when it runs only the side with low exhaust pressure, the pipes are cold. So it's like there's no combustion at all going on in that cylinder. I didn't do a compression test yet but when I crank it and put my finger over the hole it feels just like the side that runs fine. I won't find out for sure if it's bad until I do the compression test though. So I guess the only thing left if the compression is good is the reeds. Could it be anything else? Thanks for the replies! Quote
Darthwall Posted June 17, 2010 Report Posted June 17, 2010 do the aboved mentionioned and see what comes up could be jets are plugged up? Quote
CadyRidah Posted June 17, 2010 Author Report Posted June 17, 2010 do the aboved mentionioned and see what comes up could be jets are plugged up? Could carb cleaner clean that up or do I have to actually remove the jet? Quote
rockenshee Posted June 17, 2010 Report Posted June 17, 2010 Could carb cleaner clean that up or do I have to actually remove the jet? its happend to me i replaced the spark plugs and that fixed it Quote
CadyRidah Posted June 17, 2010 Author Report Posted June 17, 2010 its happend to me i replaced the spark plugs and that fixed it I tried that and it wasn't it. Quote
TeamRealtreeHD Posted June 17, 2010 Report Posted June 17, 2010 It's your reeds... take them out and replace the petal that is damaged. Quote
CadyRidah Posted June 17, 2010 Author Report Posted June 17, 2010 It's your reeds... take them out and replace the petal that is damaged. Ok, I'm gonna check that next when I have time. Thanks! Quote
