CadyRidah
Everything posted by CadyRidah
  1. Well it turned out to be a fuel problem. It wasn't getting gas. I messed with the fuel lines and problem went away. Not sure really what it was but I guess it was clogged or something and it unclogged itself.
  2. Ok, I'm gonna check that next when I have time. Thanks!
  3. I tried that and it wasn't it.
  4. Could carb cleaner clean that up or do I have to actually remove the jet?
  5. Ok it's not the coil. I did notice that when it runs only the side with low exhaust pressure, the pipes are cold. So it's like there's no combustion at all going on in that cylinder. I didn't do a compression test yet but when I crank it and put my finger over the hole it feels just like the side that runs fine. I won't find out for sure if it's bad until I do the compression test though. So I guess the only thing left if the compression is good is the reeds. Could it be anything else? Thanks for the replies!
  6. How much did the coil cost you?
  7. You might be right about the low compression. I didn't notice an air leak. The boots look fine too but I'll check them again.
  8. Anyone know what's wrong with this Banshee? It starts up but on the right side the exhaust pressure is normal and on the left side barely any pressure comes out. It's like it's barely running. Anyone know what might be the problem?
  9. OK cool thanks for the help!
  10. Thanks! Where's a good place to buy those? I checked a few sites but they don't tell you what size they are. All it says it that it's a jet kit and it includes all those things you mentioned. Also I saw a jet kit on the Toomey website. They also don't say what size they are. Do you recommend those?
  11. Thanks for the replies! I'm running pods and no air box. It runs but only runs good when the choke is half way out. When the choke is all the way the bike won't move forward it just struggles and then dies but with the choke half way out it runs fine. There's also brand new plugs in it.
  12. I have a stock Banshee and just put on some T6's and K&N air filters. What kind of tuning is necessary to make it run right? Do I need to change the jets or just adjust air/fuel? Thanks!
