dicedealer702 Posted May 28, 2010 Report Posted May 28, 2010 (edited) today I took off my stator cover and found this small spring about 3 in, sitting on the lip of my crank case behind the fly wheel. I am not sure where it came from or where it goes, maybe the stator . It's a 180 Ricky stator. Anyways if u recognizes this thin spring let me know . Thanks Edited May 28, 2010 by dicedealer702 Quote
DiSkOe*1 Posted May 28, 2010 Report Posted May 28, 2010 its a seal spring.. like crank seal looks to me... DiSkOe*1 Quote
someone82 Posted May 28, 2010 Report Posted May 28, 2010 today I took off my stator cover and found this small spring about 3 in, sitting on the lip of my crank case behind the fly wheel. I am not sure where it came from or where it goes, maybe the stator . It's a 180 Ricky stator. Anyways if u recognizes this thin spring let me know . Thanks It looks like the spring that goes around the inner lip on the crank seal, to put pressure on the seal against the crank. Quote
locogato11283 Posted May 28, 2010 Report Posted May 28, 2010 yep, thats the spring from the crank seal. Quote
dicedealer702 Posted May 28, 2010 Author Report Posted May 28, 2010 so is the spring broke?? can i put it back in the seal? or iam i going to have to replace the seal? i think it happend when i did a leak down test. Quote
Drewski Posted May 28, 2010 Report Posted May 28, 2010 I ended up breaking off a crank seal spring when my idler gear exploded. All I did was buy a new seal and replace the spring. Quote
FrankieSquid Posted May 29, 2010 Report Posted May 29, 2010 its a seal spring.. like crank seal looks to me... DiSkOe*1 Yup that's exactly what it is Quote
