Can someone please tell me why the hell my 45T sprocket is smaller then my 41T?!
I didn't count the teeth; one says 45T and the other 41. I lined the bolt holes up and the 41 Is actually bigger. Both sprockets fit the chain well, the 45T says JL(James lucky), I think the 41 is OEM
I should of counted but I was in a rush, just wanted to swap sprockets after work and get my fix real quick. Ill count them tomorrow and if the teeth match the numbers Ill post the pic or let you guys know what's up.
Turns out the james lucky has 45T but only has 40 teeth! now I have to fuckin swap it back out for the 41 again banghead I dont get it, 45T means 45 teeth :confused:
Im going to sue james lucky for wrongful loss of bottom end!
thats the dumbest thing ive ever heard. why the hell would they stamp 45 on a sprocket if it only had 40 teeth? did you call them and let them know you wanted a 45 and now have a 40 because theyre too stupid to stamp the right numbers on their sprockets?
Should've used sprocket specialists... :rotflmao:
I pulled the sprocket off a spare axle I had so I didn't specifically order it. I just wanted to gear it down for now until I burn the 22s up and get 20s. I'm just gonna put a 13 on the front and the 41 on again
