shakenbake1285 Posted May 22, 2010 Report Posted May 22, 2010 My 05 banshee will not idle unless I choke it. I let it idle with choke on for few min then noticed my left exhaust was warm while my kick starter side was still cold. Any ideas how to fix or what is causing this. Quote
#1JUANstunna Posted May 22, 2010 Report Posted May 22, 2010 Switch plugs side to side and see if the problem is in the other cylinder. Sounds like a fouled plug. http://bansheehq.com/forums/index.php?showtopic=131150 Quote
JSHEE34756 Posted May 22, 2010 Report Posted May 22, 2010 My 05 banshee will not idle unless I choke it. I let it idle with choke on for few min then noticed my left exhaust was warm while my kick starter side was still cold. Any ideas how to fix or what is causing this. I developed this problem and it turned out to be nothing more than a fouled plug on the kick side. It would idle but very rough and miss fire like crazy on the right cylinder. Switched both plugs out and back to new, However it appear that my right side is burning richer than the left so my jetting could use a tune up. BTW, the right side as I mentioned is the kick starter side same as your problem. Just some guesses. If these are ruled out pull both plugs leave the coil wires on and kick it and see if both sides have even spark, If ok, Tear the engine and inspect the pistons and rings for wear, Last would be a carb issue possibly, Other than that I think I almost stated as much as you can check for the possible problem your having. Quote
shakenbake1285 Posted May 22, 2010 Author Report Posted May 22, 2010 Ok thanks. I got the right carb tore apart to clean n c if that does anything Quote
LilShee Posted May 22, 2010 Report Posted May 22, 2010 Just switch ur plugs if it's doin the same thing on the opposite side u know it's ur plugs Quote
shakenbake1285 Posted May 22, 2010 Author Report Posted May 22, 2010 It's been awhile since I synced them how do I adjust the ping marks Quote
shakenbake1285 Posted May 22, 2010 Author Report Posted May 22, 2010 Both sides have equal spark. Quote
shakenbake1285 Posted May 22, 2010 Author Report Posted May 22, 2010 Carbs are alittle off need help on how to sync manually. Quote
shakenbake1285 Posted May 22, 2010 Author Report Posted May 22, 2010 Got it to idle fine. The little hose that connects the carbs came off (not the fuel lines) Quote
JSHEE34756 Posted May 23, 2010 Report Posted May 23, 2010 (edited) Got it to idle fine. The little hose that connects the carbs came off (not the fuel lines) Good deal, At least it was somthing simple, Tearing into your engine and carb would be the last thing to resort to. I think I am going to keep viewing this topic over and over and not for info either. For some reason I can't stop looking at the comment 5 up from wesw. Oh Wait, I know. That some nice ass and tities. Edited May 23, 2010 by JSHEE34756 Quote
wesw Posted May 23, 2010 Report Posted May 23, 2010 Carbs are alittle off need help on how to sync manually. Quote
