What's up guys, I'm planning on getting a new chain for my bike because mine has a lot of slack even with the adjustment all the way out, and I just got the back not long ago so I'm not sure what its been through. I have a stock swingarm but I don't know what to look for as in length or brand. What are u guys running and what do you suggest? Does the type of ridding I do matter when making a selection? If so I mostly ride dirt trails. Thanks a lot fellas!
stock chain is 520x104. i recommend the primary drive chain from rockymountainatv.com.
Tight, ill look into it but do you mean rockymountainatvmc.com?
Alright I found the site, but what's the difference between all the x ring, o ring, h ring, and etc?
The main difference between o-rings and x-xrings is how they seal .. o-rings have 1 sealing point (due to the o shape) and the x-rings have 2 sealing points (sue to the x shape) ... so an x-ring chain seals better (last longer).
The x-ring chain is also stronger (less overheating due to better lubrification)
Chris
