350 screamer Posted May 13, 2010 Report Posted May 13, 2010 well now that we FINALY finished the motor its a 4mil now .20 over bore....... now were just having backfire and starting problems kicking it over wont start it, the only way to start is to jump start it, and it just gets tireing i had friends watching, to make sure both cylinders were going as well as me riding it... i only thought one was... but yea were just having a problem with back fireing now we assembled it with bellray assembly lube for the wrist pins for a little more easier to put in which is burning off as well but i noticed that when the plugs are out theyre covered in gas,(theyre brand new just bought just had a quick first ride out on street to see how she ran) im thinking jetting? anybody else...... thanks to all.. Quote
98_shee Posted May 13, 2010 Report Posted May 13, 2010 Backfiring is normally a sign of a lean codition, did you do a leak down test to check for air leaks? What are you mods, elevation, temp, current jetting? Quote
firebanshee Posted May 13, 2010 Report Posted May 13, 2010 Did you get the slides back in the right carbs? Quote
350 screamer Posted May 13, 2010 Author Report Posted May 13, 2010 (edited) no, but i had a feeling the choke is supposed to be conntected... just learning new things it was like that when i bought it but now that i kno and im taking that idea of puting the slides in the wrong carbs, that i might have dont if anything and its prolly gonna need rejetting anyways.. and far as mods its got 4mil crank hot rods... hot rods pistons 20 overbore, FMF fatties and silencers.... and a hinsin 7 plate clutch pack.... and the current jetting im not sure at the moment Edited May 13, 2010 by 350 screamer Quote
98_shee Posted May 13, 2010 Report Posted May 13, 2010 no, but i had a feeling the choke is supposed to be conntected... just learning new things it was like that when i bought it but now that i kno and im taking that idea of puting the slides in the wrong carbs, that i might have dont if anything and its prolly gonna need rejetting anyways.. and far as mods its got 4mil crank hot rods... hot rods pistons 20 overbore, FMF fatties and silencers.... and a hinsin 7 plate clutch pack.... and the current jetting im not sure at the moment You had a feeling the choke is supposed to be connected?? The choke is in the side of the left carb and the choke tube is on the opposite side of the choke it is a small black tube that connects the carbs. You need a clymers manual. Quote
98_shee Posted May 13, 2010 Report Posted May 13, 2010 Are you running a spacer plate or cut domes with the 4mill? I have a pro design head with 18c dome's cut for a 4mill that i don't need. Quote
