2sTrokeLove Posted May 12, 2010 Report Posted May 12, 2010 ok guys heres the mods, pro mx ported and polished by trinity, cool head 20cc domes, bored 80 over weisco pistons, 28mm pwks ptr mid revs, stock air box with k&n +4 timing 500 feet above see level 60-90 degrees temp 155 mains not sure on needle height needle says 3.5 for size not sure on pilot it rans awesome but since i jetted it to 155 it just dont pull as hard same when i advanced the timing any advice would help please dont make jokes i listed everything i know just trying to get help form good guys that know there stuff thanks. Quote
2sTrokeLove Posted May 14, 2010 Author Report Posted May 14, 2010 ok guys heres the mods, pro mx ported and polished by trinity, cool head 20cc domes, bored 80 over weisco pistons, 28mm pwks ptr mid revs, stock air box with k&n +4 timing 500 feet above see level 60-90 degrees temp 155 mains not sure on needle height needle says 3.5 for size not sure on pilot it rans awesome but since i jetted it to 155 it just dont pull as hard same when i advanced the timing any advice would help please dont make jokes i listed everything i know just trying to get help form good guys that know there stuff thanks. cananyone help me? thought people would give advice. please and thank you. Quote
shawn941 Posted May 14, 2010 Report Posted May 14, 2010 ok guys heres the mods, pro mx ported and polished by trinity, cool head 20cc domes, bored 80 over weisco pistons, 28mm pwks ptr mid revs, stock air box with k&n +4 timing 500 feet above see level 60-90 degrees temp 155 mains not sure on needle height needle says 3.5 for size not sure on pilot it rans awesome but since i jetted it to 155 it just dont pull as hard same when i advanced the timing any advice would help please dont make jokes i listed everything i know just trying to get help form good guys that know there stuff thanks. what octane gas you running with 20cc domes? and whats your compression? Quote
98_shee Posted May 14, 2010 Report Posted May 14, 2010 The main sounds close. Why did you rejet, what was your jetting before you rejeted it? I had a bike with simular mods without an airbox and it was jetted at 158 main, 48 pilot, N68a needle middle clip, air screw 1.5 turns out. Quote
Larry's Shee Posted May 15, 2010 Report Posted May 15, 2010 Timing plate or key? If key maybe you put it in backwards. Why did you change jets?What were jets you took out ?Did you change anything else at the same time ? Try it with jets you took out. Quote
2sTrokeLove Posted May 15, 2010 Author Report Posted May 15, 2010 Timing plate or key? If key maybe you put it in backwards. Why did you change jets?What were jets you took out ?Did you change anything else at the same time ? Try it with jets you took out. its a timing plate, i jetted it because it was sputtering out one carb bad. when i jetted it it came alive then when i did the timing it just dont pull the same i smoked my buddys yfz like nothing an now it stays with or passes me so i got something wrong..lol im runnin 93 oct. not sure on compression yet, i jetted it down to 150 main an it does a little better but that shouldnt be right should it i should have to jet up? Quote
98_shee Posted May 15, 2010 Report Posted May 15, 2010 Did you sync the carbs? You should do a plug chop to see if 150 is to lean. Quote
2sTrokeLove Posted May 15, 2010 Author Report Posted May 15, 2010 Did you sync the carbs? You should do a plug chop to see if 150 is to lean. carbs are sync, i do need to do a plug chop though. Quote
streakx Posted May 17, 2010 Report Posted May 17, 2010 does it revs easy but doesn't pull that hard ? if so probably lean ... also make sure you didn't -4 your timing (sometimes we do some dumb shit without being dumb lol) Also .. does it pull ok from 0 to 1/2 throttle (like before) ? Chris Quote
2sTrokeLove Posted May 17, 2010 Author Report Posted May 17, 2010 does it revs easy but doesn't pull that hard ? if so probably lean ... also make sure you didn't -4 your timing (sometimes we do some dumb shit without being dumb lol) Also .. does it pull ok from 0 to 1/2 throttle (like before) ? Chris timing is right..lol but shit does happen, ya it still gos good up to half way throttle response is awesome. Quote
streakx Posted May 18, 2010 Report Posted May 18, 2010 timing is right..lol but shit does happen, ya it still gos good up to half way throttle response is awesome. Shee needs bigger main jets Chris Quote
2sTrokeLove Posted May 18, 2010 Author Report Posted May 18, 2010 Shee needs bigger main jets Chris k ill try bigger a report back. anyone got bigger jets for kein carbs? Quote
