so you think take them out and clean them? even if tehy were dirty you think it would still run good once started? thanks again for all the help guys
Dont clean out the stock pilot jets.......go out and get yourself a set of 27.5 pilot jets. They will keep you from running rich on the low end of your shee's throttle. if your bikes pilot circuit is running lean it will definately make it hard to start.
ok i went with the 27.5 pilot adn cleaned out the cabrs which were clean already. Still same problem. Also changed back to the stock needles. I put a tiny drop of gas in each carb and bam! starts first kick and then every kick after that till i let it sit for the night. Its drivn me crazy!!!
