BigMatt Posted April 22, 2010 Report Posted April 22, 2010 I just advanced my timming +4 my setup is trail port, wesco pistons. I'm alittle worried about detonation, all though I'm running 93oct/ 40-1 r-50 klots, its alittle oil rich, my plugs are just alittlle dark unless all I do is rip on it than there golden, I'm going to try 50-1 but was wondering I dont want to start mixing race fuel but am alittle nervouse about detonation is there any way to tell if your detonating before its to late, I know about plugs coming loose, but mine are socked down, what should you tourque your spark plugs down to L.B. if there to tight than detonation wont lossen them will it? thanks alot guys, Quote
Profilact Posted April 23, 2010 Report Posted April 23, 2010 Do a compression check to find your octane requirments. While timing is a factor, compression is the main factor. Quote
WINDYCITYJOHN400 Posted April 23, 2010 Report Posted April 23, 2010 Tight plugs won't prevent detonation problems....if the plugs don't back out, the O-rings or head gasket will just blow out. Once that happens, and you quench the hot pistons with water and the ring lands squish down and clamp the rings you can plan on a new set of pistons. (It happend to me, it could happen to you.) Stay at 40:1. 50:1 won't make you more power. Race fuel doesn't CAUSE detonation...it PREVENTS it. Check you compression and then ask about fuel needs based on the compression. If you can do a squish check it will help with the info also. Quote
BigMatt Posted April 23, 2010 Author Report Posted April 23, 2010 Tight plugs won't prevent detonation problems....if the plugs don't back out, the O-rings or head gasket will just blow out. Once that happens, and you quench the hot pistons with water and the ring lands squish down and clamp the rings you can plan on a new set of pistons. (It happend to me, it could happen to you.) Stay at 40:1. 50:1 won't make you more power. Race fuel doesn't CAUSE detonation...it PREVENTS it. Check you compression and then ask about fuel needs based on the compression. If you can do a squish check it will help with the info also. my compression is around 120-125 warm, I know race fuel prevents it. but was wondering if I was rich on oil, than that could in turn... dilute the gas bringing the octane level down causing detonation, I could be wrong just want to make sure. also I have a stock head with no milling. i ment to type Wiseco pistons Quote
toolman Posted April 23, 2010 Report Posted April 23, 2010 With that compression you do not have to worry. I run 180psi on pump gas and have not had any problems. (I'm sure this going to start some shit) But it is true and yes I have good guage. Quote
Profilact Posted April 23, 2010 Report Posted April 23, 2010 thats quite amazing there toolman. Hey if it works for ya do it, but in theory it shouldn't. Quote
BigMatt Posted April 24, 2010 Author Report Posted April 24, 2010 thats quite amazing there toolman. Hey if it works for ya do it, but in theory it shouldn't. so im good? thanks guys got a trip planed to silver lake and want to make sure is all good! Quote
firebanshee Posted April 24, 2010 Report Posted April 24, 2010 so im good? thanks guys got a trip planed to silver lake and want to make sure is all good! No worries Quote
WINDYCITYJOHN400 Posted April 24, 2010 Report Posted April 24, 2010 so im good? thanks guys got a trip planed to silver lake and want to make sure is all good! If your going to Silver Lake the bigger concern should be to do some plug cops when you get there to make sure your jetting is good. ( Alot of times Banshee jettings aren't set up for all the high speed, wide open riding like you find in the dunes.) I think you'll be fine with that timing at your compression. Enjoy the sand. I won't make it up there till late May. Quote
fastquad02blaster Posted April 24, 2010 Report Posted April 24, 2010 When you pull your plugs to check them, look for little grey specks on the porcelain. They say on here that it's little peices of your piston, caused by detonation. Quote
BigMatt Posted April 24, 2010 Author Report Posted April 24, 2010 When you pull your plugs to check them, look for little grey specks on the porcelain. They say on here that it's little peices of your piston, caused by detonation. thanks for all the good info, my jetting and mix would be great for dunes, when I rip on it hard the plugs look good, its when I trail ride they look alittle dark. Quote
mopar1rules Posted April 25, 2010 Report Posted April 25, 2010 what mods does your shee have and what is current jetting? Quote
AKheathen Posted April 26, 2010 Report Posted April 26, 2010 adjust your airscrews and/or needles Quote
