POORBOY350 Posted April 15, 2010 Report Posted April 15, 2010 i need to know where the best/cheapest place i can get an override is, and how much im lookin at spending. prob go with the dunable or which ever one is the most usable since i do more than just drag. need some help putting it in to... never owned one before. was gonna sell the banshee but nobody has any loot right now so guess ima put some in it while i got it. also im chasing a water leak down(water getn in oil and oil in water.wtf), needin some help. replaced water pump stuff one time didnt fix it apparently... thanks. Quote
AKheathen Posted April 16, 2010 Report Posted April 16, 2010 did you replace the o-ring where the tube mates between the cases and clutch cover? is your impeller shaft grooved out? also, check your case vent and overflow hoses....mabey you connected the wrong one to the radiator. Quote
RagunCajun Posted April 16, 2010 Report Posted April 16, 2010 I recommend a n-down 1-5 duneable override. Love mine. And you can replace all your seals while you are on there. Might solve your leak problem. Putting one in is as simple as taking the old one out and putting the new one in if you dont send in a core. Mine was $425 and it was from a friend of a member on here. Quote
POORBOY350 Posted April 21, 2010 Author Report Posted April 21, 2010 did you replace the o-ring where the tube mates between the cases and clutch cover? is your impeller shaft grooved out? also, check your case vent and overflow hoses....mabey you connected the wrong one to the radiator. took everything apart today and my impeller shaft did have some lil grooves in the middle 3 lil ones, whats that mean anyway? and there is a very small crack on inside of cover where the impeller bearing sits. i think im just gonna order new gaskets and get o'rings for tube and head and see if that helps. Quote
camatv Posted April 22, 2010 Report Posted April 22, 2010 i'd just buy a cover also. get on ebay and get one for 25 bucks or so.. Quote
firebanshee Posted April 23, 2010 Report Posted April 23, 2010 Redline sells duneable overrides for $400 and he cuts his own. One of the best mods you can do to your bike.imo Quote
POORBOY350 Posted April 23, 2010 Author Report Posted April 23, 2010 Redline sells duneable overrides for $400 and he cuts his own. One of the best mods you can do to your bike.imo definately. it destroys clutch plates (: gotta get this water leak tightened up before i can do anything else tho. Quote
