prices are without shipping, insurance, and tracking. parts are off a 92 banshee
clutch- magnum basket with primary gears, newer inner and outer hubs, fast clutch, and stock and heavy springs. parts have some wear but worked good. $80 for all
YFZ450 front end a arms, shocks, and custom aluminum tie rods. lower arms are modified to fit on the banshee and tie rods are for mounting on the banshee. $250
trinity single carb kit with 38mm pwk airstriker, pod filter and outerwears, braided stainless cable, and back half of airbox for a splashguard $200
cases no breakage, can include shift forks $100
shift shaft with aftermarket spring $10
shifter lever $10
kicker lever detent was rebuilt and still snaps in place $10
internal kicker gears $15
front spindles and hubs $40
coil and cdi $45
front brake system complete $40
stock a arms and tie rods some of the boots are ripped $40
rear brake system including pedal $30
lower motor mount struts including new bushings and solid aluminum bushings. $20
stator on adjustable timing plate + stock plate $40
clutch cover stock, no water pump $15
stator cover stock, cut out behind shifter so it can be removed without removing shifter $10
grab bar stock $15
aluminum skid plate a little beat up $15
dog bones 2 $10 each
tail light $10
pingel tether $10
sprocket mount 6 bolt $10
radiator $10
fmf ram valves newer reeds $20
plastic heel guard pieces $10
frame with dnr card local pickup only $100
other parts that could be negotiated in with some of the bigger parts or related parts
clymer service manual
flywheel puller
new motion pro clutch cable
41T sprocket
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
shifter lever $10
coil and cdi $45
grab bar stock $15
tail light $10
pingel tether $10
radiator $10
flywheel puller
41T sprocket
do you have the factory nerf bars to go with the heel guards?
I would like the stator package for $40.00. I also live in Virginia.
If your close I can pick it up or just reply with payment details.
Thanks,
Troy
Thanks,
Troy
i couldnt pm you. either add $10 for shipping or send me your zip for a shipping price. my paypal is [email protected]
Pics of the skid plate.
i have never figured out how to resize pics right to post them so if you want pics send me your email.
if this stator doesn't work out i am desperate for one! need shiping to salisbury, nc 28147 funds in hand!
Thanks
Shipping Zip is
Va beach Va 23453
I send payment as soon as I hear back from ya :headbang:
Thanks
Shipping Zip is
Va beach Va 23453
Hey it's Troy again. Sounds like the guy from Salisbury NC needs this quicker then I do ( Pondtunes)
Please feel free to close the deal with him.
I'll catch the next one that comes along.
Thanks,
Troy
Thanks,
Troy
Damn troy you rock man! I owe you big time
