Hey everyone,
New to site and Banshees! first love these bikes. I have an issue, I was out riding Saturday everything was workin great. I came down from a 6th gear run to an idle when the bike started to run on only one cylinder? Like I said I am new to all 2-stroke pros and cons. I really need some advice on what the problem may be. Any and all help will be greatly appreciated!
Thanks in advance!
Look for leaks Igot a 2into1 and i was ready to smash my carb but found a leak between the jug n case
Hey everyone,
Thanks in advance!
I will check it out tonight, thanks!!!
Hey everyone,
Thanks in advance!
A banshee does not like to be held wide open in 6th gear for too long without varying the throttle up and down some. If you are jetted on the ragged edge (on the lean side) then you could smoke a piston doing that for too long. Take out your plugs and look at them, see if they are brown or if they are the same color. You can also look down in the spark plug holes with a light and see if the tops of the pistons look ok.
