Ny-2stroke4ever Posted March 23, 2010 Report Posted March 23, 2010 ok i dont know if this was talked about before but i cant find any info unless im looking up the wrong things. if it was talked about can someone post the thread. i have a 2005 banshee that i just put a 4 mill crank in. the problem is i cant get the 35mm carbs to fit with the stock air box. i have v force 3 reeds and manifolds with built in crossovers. can i use my stock air box and modify it or do i have to run the pods? any help is greatly appreciated thanks Quote
bansheesandrider Posted March 23, 2010 Report Posted March 23, 2010 ok i dont know if this was talked about before but i cant find any info unless im looking up the wrong things. if it was talked about can someone post the thread. i have a 2005 banshee that i just put a 4 mill crank in. the problem is i cant get the 35mm carbs to fit with the stock air box. i have v force 3 reeds and manifolds with built in crossovers. can i use my stock air box and modify it or do i have to run the pods? any help is greatly appreciated thanks I know there are aftermarket boots available to connect the airbox to bigger carbs, but I don't know who has them. I would Googlr Banshee airbox boots or try FAST, Cascade, or some of the other vendors, maybe Modquad. Quote
Ny-2stroke4ever Posted March 23, 2010 Author Report Posted March 23, 2010 I know there are aftermarket boots available to connect the airbox to bigger carbs, but I don't know who has them. I would Googlr Banshee airbox boots or try FAST, Cascade, or some of the other vendors, maybe Modquad. o sorry i didnt specify it but i got the 35mm carb boots i juz cant get the carbs 2 fit in between the manifolds and air box. the carbs actually hit the air box. sorry for the mistake Quote
papa_smurf49319 Posted March 23, 2010 Report Posted March 23, 2010 you might have to take a chunk outta the middle of the airbox and attach it back together, or you might have to move the airbox back in the bike. Quote
Ny-2stroke4ever Posted March 23, 2010 Author Report Posted March 23, 2010 you might have to take a chunk outta the middle of the airbox and attach it back together, or you might have to move the airbox back in the bike. yea thats what i thought i just wanted 2 make sure before i did anything and f****d it up Quote
sleeper06 Posted March 23, 2010 Report Posted March 23, 2010 A company called upp makes the boots and I have moved many air boxes back to accomodate bigger carbs,it takes a little fabrication,a little cutting.If you need me to move it let me know i can give you a hand. Whatever you do dont take a chunk out of the middle thats the dumbest idea Ive heard,I have ways to get around that Quote
jbooker82 Posted March 23, 2010 Report Posted March 23, 2010 Air box with larger carbs is a big pain in the butt. I ran my stock one for a while but got tired of trying to wedge the carbs in there. POD's are much easier. Quote
papa_smurf49319 Posted March 23, 2010 Report Posted March 23, 2010 A company called upp makes the boots and I have moved many air boxes back to accomodate bigger carbs,it takes a little fabrication,a little cutting.If you need me to move it let me know i can give you a hand. Whatever you do dont take a chunk out of the middle thats the dumbest idea Ive heard,I have ways to get around that I agree the chunk in the middle isnt the best idea and i would try and move it back first, just had another member suggest the chunk in the middle thing to me so i figured id pass it on. I ditched the box and went with pods, but the box is nice. Quote
Ny-2stroke4ever Posted March 23, 2010 Author Report Posted March 23, 2010 A company called upp makes the boots and I have moved many air boxes back to accomodate bigger carbs,it takes a little fabrication,a little cutting.If you need me to move it let me know i can give you a hand. Whatever you do dont take a chunk out of the middle thats the dumbest idea Ive heard,I have ways to get around that yea i got the upp boots alredy and i def wont take the chunk out cuz it seriously would be dumb. but lemme c what i can do first before i bother u again lol.. i might end up gettin the pods 2 but what u runnin carl? pods? Quote
