9banshee6 Posted March 17, 2010 Report Posted March 17, 2010 my right pipe sounds perfect while idling! ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding and my left one sounds like shit dingding ding.. ding........ ding ding ding.............. ding.. ding .ding ding ding ...........................................ding and my right one you could see the smoke coming out and on the left you cant air is coming out nice and c=hard on the right and on the left you could barley feel it! also the left one you could bearley even hear while the right on e is all loud and when you take off the right one sounds like this RRRRAAAAAAAAAAAAAWWWWWWRRRRRRRRRR! AND LEFT pipe sounds dosent sound like The right at allIT SOUNDS LIKE tuck tuck tuck tuck tuck sound and thers no power at all but if you give the throttle slowly by slowly by the time it reaches to about half throttle my left pipe starts sounding perfect and thers power. whats happening hear its not the jets cause i got it jetted not long ago got some fresh plugs what the could it be! please help me!!! Quote
Badbar88 Posted March 17, 2010 Report Posted March 17, 2010 Mine sounded kinda like that when a peddle in one of the reeds broke off. Quote
banshee#44 Posted March 17, 2010 Report Posted March 17, 2010 my right pipe sounds perfect while idling! ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding ding and my left one sounds like shit dingding ding.. ding........ ding ding ding.............. ding.. ding .ding ding ding ...........................................ding and my right one you could see the smoke coming out and on the left you cant air is coming out nice and c=hard on the right and on the left you could barley feel it! also the left one you could bearley even hear while the right on e is all loud and when you take off the right one sounds like this RRRRAAAAAAAAAAAAAWWWWWWRRRRRRRRRR! AND LEFT pipe sounds dosent sound like The right at allIT SOUNDS LIKE tuck tuck tuck tuck tuck sound and thers no power at all but if you give the throttle slowly by slowly by the time it reaches to about half throttle my left pipe starts sounding perfect and thers power. whats happening hear its not the jets cause i got it jetted not long ago got some fresh plugs what the could it be! please help me!!! haha i lmao reading this, and would just like to thank you cause i have no idea what your problem could be Quote
FrankieSquid Posted March 17, 2010 Report Posted March 17, 2010 I like how descriptive he can get. braaap brappp, ding ding ding.......ding ding.....ding ding. Sorry i got carried away. I was thinking it might be a plug fouling or try swapping the plug wires and see if it changes to the other side, if it does it might be a cdi issue, try putting in new plugs if you already have not done so. Quote
9banshee6 Posted March 17, 2010 Author Report Posted March 17, 2010 I like how descriptive he can get. braaap brappp, ding ding ding.......ding ding.....ding ding. Sorry i got carried away. I was thinking it might be a plug fouling or try swapping the plug wires and see if it changes to the other side, if it does it might be a cdi issue, try putting in new plugs if you already have not done so. ya i already switched the cables but it still the same and my spark plugs are like new so it cant be that. so what could be wrong whit my cdi box? Quote
FrankieSquid Posted March 18, 2010 Report Posted March 18, 2010 ya i already switched the cables but it still the same and my spark plugs are like new so it cant be that. so what could be wrong whit my cdi box? Well if you switched your cables and the same cylinder is getting the same symptoms, then you should clean out your carbs. It may be a fuel issue. Open them suckers up clean the bowls the jets and everything in between. That happen to my shee and it was a plug. Throw some fresh plugs in there it's just a few bucks. Even they may be like new they can get fouled or start to get fouled. Throw some fresh ones in there to take out that probability. I don't think it's your CDI. Quote
bansheekx Posted March 19, 2010 Report Posted March 19, 2010 A plugged up pilot jet will not allow any fuel to reach the cylinder until you open the throttle enough to open the main jet. I would try a new sparkplug first and then open up the carb and clean it. Quote
J-Madd Posted March 19, 2010 Report Posted March 19, 2010 Could be reeds, air leak, or dirty carb, but Im still gonna say the carbs aren't sync'd. Check them again. I fought that for a long time and swore the carbs were in sync. Somehow the cable was in a bind given the appearance that they were sync'd, then later while riding it would free itself, then they would be way out of sync. If that doesn't work you could swap carbs left to right and see if the problem follows. Quote
9banshee6 Posted March 19, 2010 Author Report Posted March 19, 2010 Could be reeds, air leak, or dirty carb, but Im still gonna say the carbs aren't sync'd. Check them again. I fought that for a long time and swore the carbs were in sync. Somehow the cable was in a bind given the appearance that they were sync'd, then later while riding it would free itself, then they would be way out of sync. If that doesn't work you could swap carbs left to right and see if the problem follows. ya why is it that when i sync mt carbs then ride it them check them again ther out of sync and how do i stop this? Quote
gmctruck1976 Posted March 26, 2010 Report Posted March 26, 2010 ya why is it that when i sync mt carbs then ride it them check them again ther out of sync and how do i stop this? ive kinda got the same issue on a single carb. It \happen to be plug failing, stilll get it time to time but i am running a little rich for break in. how dose it run as far as running. is it faling plugs or what. Quote
