hopefully someone can help me. my banshee when i bought it would move forward even when the clutch was pulled in. i ws told this could be caused by a worn inner or outer clutch hub and the clutch was do to be replaced. i replaced the clutch,inner hub,outer hub,and clutch cable cuz it looked old.got clutch adjustment behind side case as close as possible being that the alignment mark on the left side is non existent cuz that piece of crankcase is broken.any ideas or comments greatly appreciated! i think its a adjustment prob on the clutch it self but not sure.
Thanks Gurnzz
The clutch actuator arm should point straight back when you push on it by hand until resistance is met. If it's adjusted correctly, you probably just need to tighten the clutch cable.
thanks for the feed back J-Madd,
ok so when i make the adjustment on the side should the clutch cable adjustment on the handle bars be all the way backed off or should there be tension on it? also just to make sure i got what u said about the arm. i should hold it with my finger so its pointing straight back and turn the adjuster screw on the clutch hub till i feel resistance on the arm and then i should lock down the jam nut once i feel resistance? I just want to make sure i get it right this time!
Don't worry about the cable until you get the actuator set. It sounds like you know how to do that. ON the clutch lever on the handle bars, normally you want a little play. I dont' remember the spec , but you don't want it so tight that the clutch stays engaged. Maybe about a nickels width between the perch and lever before you really feel tension. I always run mine just tight enough so the it doesn't want to creep forward with the clutch pulled in...it's safer running it loose than tight. You can literally fry a clutch in minutes if you run it too tight.
ok thanks again J-Madd, your help is much appreciated. ill def run it a lil loose !
  • 2 weeks later...
hey J-Madd i set the actauator so the arm so its straight back, adj the cable and it seemed great untill !!! heres whats happening. say im riding it and i have to stop in a trail behind someone for whatever reason. i pull in the clutch while its still in gear,and in about 5 seconds you can feel the clutch getting funny in your hand and then shee tries to move forward even tho clutch is still pulled in, then it seems like whatever is taking place with the clutch it feels like it partially engages and shee wants to stall out unless u let the clutch out and continue forward. cant figure it out. Any ideas from anyone on what to maybe look at or where to go from here would be greatly appreciated!
Thanks Gurnzz
Thanks Gurnzz
What kind of Gear Oil you running? Stock or aftermarket clutch? I had that same issue with my dirt digger running certain non- synthetic oils. I starting usiing full synthetic gear oil and it never did it again.
Yeah, I'm leaning toward the oil also. Maybe try something different.
I am using BelRay Gear Saver SAE 85 with my Dirt Digger and stronger springs with excellent results. Stopped my creeping issue. Seemed like all the oil was flinging out of the clutch pack causing friction and therefore the creeping. :)
hey sandduner i have an aftermarket clutch and i cant remember what fluid i just recently put in it but ill def look into that. ii still have the botle out in the garage. ill let you know how i make out. thanks for the response !
thanks everyone for the feed back ! ill change the fluid tomorrow and ill let you guys how i make out. hopefully thats all it is.
Thanks Gurnzz. everyone have a good weekend !
  • 2 weeks later...
So how did it go? Let us know. Thx. B)
