3lue by u Posted March 15, 2010 Report Posted March 15, 2010 I know they say type F works and I tried it out on mine and put it in and went on a ride down in southern ohio. Changed the fluid out and went to take off and the quad wouldnt move, drained all of it out and put gear oil in it "thick" and it made it through half of the ride clutch was slipping horribly on the ride back to the trailer. I think it has something to do with the thinner atf more or less washing the old worn clutch and causing the slip. Quote
RadarRacing Posted March 15, 2010 Report Posted March 15, 2010 We run $2 qt Type F trans fluid in our dragbikes , duners, and trailbikes. An automatic transmission has gearsets and clutchpacks under high loads and heat just like a banshee trans. Of course don't run it in a 4 stroke quad that needs oil for the crank too. Quote
