banshee 268 Posted March 8, 2010 Report Share Posted March 8, 2010 hi i was just wondering if i had to do the stroker crank with the 421 big bore or if i could just bolt it on.also do i have to have the cases bored out for this kit also and would this big bore be any good for circle track racing and ice racing.if not what big bore would be the best way to make big hp Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 8, 2010 Report Share Posted March 8, 2010 you can essentially build any kind of setup to be as big as you want. the possibilities are endless.. there are a few however that are cheaper and make awesome power.. it sounds to me like you need to go with a 4mm cub which is a 421cc motor. the crank drops in without any modifications. Quote Link to comment Share on other sites More sharing options...
banshee 268 Posted March 8, 2010 Author Report Share Posted March 8, 2010 (edited) you can essentially build any kind of setup to be as big as you want. the possibilities are endless.. there are a few however that are cheaper and make awesome power.. it sounds to me like you need to go with a 4mm cub which is a 421cc motor. the crank drops in without any modifications. k with the 4mill cub do i have to run the crank.or is it just not worth runnung it with out.also where is the best place to get it from Edited March 8, 2010 by banshee 268 Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted March 8, 2010 Report Share Posted March 8, 2010 Yes, thats what makes it a 4mill. With smaller engines you will not gain tons of power on bore size alone. Thats where the stroke comes in. Now on a large V8 sure, but there are alot more pistons, and they are larger so they all add up to make the large power increase. Make sense? Quote Link to comment Share on other sites More sharing options...
banshee 268 Posted March 8, 2010 Author Report Share Posted March 8, 2010 Yes, thats what makes it a 4mill. With smaller engines you will not gain tons of power on bore size alone. Thats where the stroke comes in. Now on a large V8 sure, but there are alot more pistons, and they are larger so they all add up to make the large power increase. Make sense? k thanks for the info.where is the best place to get it from Quote Link to comment Share on other sites More sharing options...
over960 Posted March 8, 2010 Report Share Posted March 8, 2010 Hello this is Kevin from shikago I'm listen about this site from my friend so today This is my first post here Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted March 8, 2010 Report Share Posted March 8, 2010 k thanks for the info.where is the best place to get it from i got everything i needed from FAST he's a site sponsor, has very reasonable rates and great customer service heres what i got hotrods long rod 4mil crank with extra weld 68mm cub cyls noss head piston kit billet intakes 35mm keihins gasket kit etc. Quote Link to comment Share on other sites More sharing options...
banshee 268 Posted March 8, 2010 Author Report Share Posted March 8, 2010 i got everything i needed from FAST he's a site sponsor, has very reasonable rates and great customer service heres what i got hotrods long rod 4mil crank with extra weld 68mm cub cyls noss head piston kit billet intakes 35mm keihins gasket kit etc. how much hp are u making with that set up Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted March 8, 2010 Report Share Posted March 8, 2010 enough haha i don't know it's never been dynoed, it could make a lot more if i switched to cpi pipes which i really want to but i'm too cheap because work is slow at the moment if i had to make a guess i'd say somewhere around 65-70hp but i could be way off Quote Link to comment Share on other sites More sharing options...
