i just got a 421 cub and the guy said he ran race gas and premium mix i want to run full race gas what size domes do i need, its a trinity head
I run a 21cc dome on a 68mil cub and pump 180psi at sea level. If you run a smaller dome with a 68mil bore at sea level then your compression will get way high, and you will lose alot of overrev on your motor. Alot of compression will give you alot of torque and bottom end and kill your top end. With a gas motor +4 timing would be a good starting point.
Edited by firebanshee
alot of guys like using the cub on low compression around 165-170 seem to get more volume, from what ive tried
Hey, is that a stock stroke cub? is it ported?
Whats overrev? I've heard of it but never understood what it means...
It's a 4mil stroke, and the cylinder has been decked and ported. If you have to much compression then the motor has to fight against itself and does not allow the motor to rev up as far or as quickly. B)
