ok so right now to pull the clutch lever on my banshee is pretty hard... i mean its do able but for long trail rides like i do involves alot of clutch play and pulling it in all the time can get tiresome and im thinking its alittle stiffer than it needs to be.... right now i have some aftermarket clutch springs in it and i noticed that they were alittle longer and stiffer than the stock springs?? so my question is do you think putting the stock springs in would make the clutch pull alittle easier or are the aftermarket springs better to have?? keep in mind i got the bike with the aftermarket springs in it...
The question is.. Are the aftermarket springs really needed? what mods do you have done to the bike.. You might beable to get by with 3 stock springs and 3 HD springs. You could try a aftermarket clutch lever/perch. Jeff @ Fast sells a nice piece and when used with a well lubed cable it isn't nothing to pull all 6 HD springs.
Always make sure you cable is well lubed...
Well said, i run all 6 hd clutch springs, but i also have a brand new cable and lever. Its nothing to pull 6 of those springs.
Cody
