the goon Posted February 12, 2010 Author Report Share Posted February 12, 2010 Your banshee can be extremely reliable. You will have to replace the worn out stuff and build her up right, but that wont break the bank. You can rebuild your topend for around $300. If you need to replace your crank, you can get a good used one from someone around here for $100 or so. We can help you build your bike and make it reliable. Your not riding a banshee if you stick a 4stroke in it, your actually date raping it. i know it was bad but iam on the edge with it and i was losing my faith in the banshee iam going to rebuild the whole lot but in in england and the banshees are disapearing everyones 4stroke so parts are harder to get and there double what you guys pay! englands shit for banshee riders Quote Link to comment Share on other sites More sharing options...
the goon Posted February 12, 2010 Author Report Share Posted February 12, 2010 where are you located? there might be someone close to you that can help you out. Help need trick engine!! Quote Link to comment Share on other sites More sharing options...
the goon Posted February 12, 2010 Author Report Share Posted February 12, 2010 Help need trick engine!! Iam in the uk ;( Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 12, 2010 Report Share Posted February 12, 2010 there are plenty of builders that sponsor bansheehq that ship parts all over the world. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 13, 2010 Report Share Posted February 13, 2010 There is a guy on here with the screen name of "the british guy", maybe he can also help you with local parts. Might be able to search membership list for either "British" or UK. might find others in UK that could help. Many good peeps here that can help tho. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted February 13, 2010 Report Share Posted February 13, 2010 If it is an abused quad, you just need to bite the bullet and do a complete teardown and rebuild. Replace all the bearings in the engine and tranny, get a new or rebuilt crank, bore it and get new pistons, make sure the clutch, gears, shafts, shift forks are all in good shape. Replace anything that looks questionable and make sure all the threads in the cases and covers are good, Heli Coil them if needed. Then put it all together by the book with good quality gaskets and seals. Quote Link to comment Share on other sites More sharing options...
Pasi S. Posted February 13, 2010 Report Share Posted February 13, 2010 (edited) I think I have a solution for you. You are living in England?! There are many builders for Yamaha RD/RZ 350 streetbike in England. They know how to fix your engine. I also think that there is huge amount of used parts that fits to your engine. Find a local forum for those street bikes. -Pasi S. like this one.. http://www.vintagebike.co.uk/forum/ Edited February 13, 2010 by Pasi S. Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted February 13, 2010 Report Share Posted February 13, 2010 There was actualy a banshee on ebay with a yfz450 motor on ebay a while back. lots of work though... Quote Link to comment Share on other sites More sharing options...
the goon Posted February 13, 2010 Author Report Share Posted February 13, 2010 There was actualy a banshee on ebay with a yfz450 motor on ebay a while back. lots of work though... thanks guys ive found somone to rebuild my engine iam getting a cub 460 kit and having the lot rebuit thanks for all your help and posts Quote Link to comment Share on other sites More sharing options...
