Damnit Bob Posted February 11, 2010 Report Posted February 11, 2010 All 4 foot peg frame holes are all striped to hell. One hole actually had a nut poorly welded in that broke off and is just rattling around now. Theres really not enough wall thickness left for a helicoil. What have you guys done to fix striped out frames?? Quote
01banch Posted February 11, 2010 Report Posted February 11, 2010 My 250r frame was the saem way everything would strip if i tightened things down. I would drill all the way through and nut the other side. Quote
bholmes Posted February 11, 2010 Report Posted February 11, 2010 Drill through like 01banch said and weld the nut on the other side if you don't want to have to worry about it. What I did on mine was bore the hole out big enough to put a nut in the frame and then weld it up. Doin it like 01banch said will keep you from having to use a welder though if you don't weld or don't have access to a welder. Quote
WantABanshee Posted February 12, 2010 Report Posted February 12, 2010 (edited) Fix it right. Drill it and weld a nut in. I've always got a really long stud that i would hold on to with my welding gloves. Then thread a nut on it so you can hold it in place while you weld the nut. I couldn't imagine drilling through the frame Edited February 12, 2010 by WantABanshee Quote
Damnit Bob Posted February 12, 2010 Author Report Posted February 12, 2010 yeah im thinking welding a nut in there is probably best. has anyone used a long threaded rod that goes all the way thru both sides and use nuts outside the footpegs? Quote
wadlesw96 Posted February 14, 2010 Report Posted February 14, 2010 Thats what i did on mine just put a threaded rod all the way through then you can really tighten it up with a wrench on each side. Mine just has the rod through the back because my front holes are fine. But i am very happy with how the rod works made the pegs really solid. Quote
tundish2800 Posted February 14, 2010 Report Posted February 14, 2010 I had to do that last year. I can get pics if you want to see it. Weld a nut in there. If your frame is powder coated watch out cause the coating will catch fire. Quote
90lxsleeper Posted February 15, 2010 Report Posted February 15, 2010 o my 98 i had to the rear peg bolts...and i just drilled them out and used 1/2" all thread with nylon lock nut on each end Quote
T_Shee Posted February 15, 2010 Report Posted February 15, 2010 All 4 foot peg frame holes are all striped to hell. One hole actually had a nut poorly welded in that broke off and is just rattling around now. Theres really not enough wall thickness left for a helicoil. What have you guys done to fix striped out frames?? is this from when rhino wiped you out at badlands? lol j/k Quote
