paintedtoast Posted February 7, 2010 Report Share Posted February 7, 2010 As the Title states, I just traded my yz426 for an 89 banshee with ups that are located in my signature, it will be a primary dune bike and was wondering if there was anything i should replace just to avoid any hassle. I will be using the 927 2stroke oil at a ratio of 32:1 for this bike, Any help is greatly appreciated and I will get some pics up of her as soon as it stops raining! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 7, 2010 Report Share Posted February 7, 2010 welcome to HQ bro there are tons of things that could be replaced, but that doesnt mean they need to be. how does the bike feel? nice and tight? no weird noises, popping, etc? its always good to check front wheel bearings and axle play. id check it over and make sure all the nuts and bolts are tight. other than that, have fun riding it! Quote Link to comment Share on other sites More sharing options...
paintedtoast Posted February 7, 2010 Author Report Share Posted February 7, 2010 welcome to HQ bro there are tons of things that could be replaced, but that doesnt mean they need to be. how does the bike feel? nice and tight? no weird noises, popping, etc? its always good to check front wheel bearings and axle play. id check it over and make sure all the nuts and bolts are tight. other than that, have fun riding it! actually the bike is really nice for its age, no weird noises, and the front axle has no play whatsoever actually checked that part out before we did the trade, im just thinking of things that on the older banshees became a problem, im going to be replacing the rear sprocket/chain and the stock waterpump to a billet pump, and from there just trying to keep the matenance side of things working good so i can get the full life out of her. anything i should change for the desert such as to a larger radiator or anything of that nature? Quote Link to comment Share on other sites More sharing options...
madjimmax Posted February 7, 2010 Report Share Posted February 7, 2010 actually the bike is really nice for its age, no weird noises, and the front axle has no play whatsoever actually checked that part out before we did the trade, im just thinking of things that on the older banshees became a problem, im going to be replacing the rear sprocket/chain and the stock waterpump to a billet pump, and from there just trying to keep the matenance side of things working good so i can get the full life out of her. anything i should change for the desert such as to a larger radiator or anything of that nature? No need for a larger radiator right now you'll be fine, But for sure change the impeller and fill the radiator with Engine Ice instead of regular antifreeze and you might want to pick up a set of paddles. Other then that you should be fine. Ride it like you stole it. And by the way if you need to buy anything check out our site sponsers they're a bunch of kick ass dudes and their customer service cant be beat. Quote Link to comment Share on other sites More sharing options...
volcrano Posted February 7, 2010 Report Share Posted February 7, 2010 No need for a larger radiator right now you'll be fine, But for sure change the impeller and fill the radiator with Engine Ice instead of regular antifreeze and you might want to pick up a set of paddles. Other then that you should be fine. Ride it like you stole it. And by the way if you need to buy anything check out our site sponsers they're a bunch of kick ass dudes and their customer service cant be beat. definately grab a case saver!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 7, 2010 Report Share Posted February 7, 2010 definately grab a case saver!!!!!!!!!! if you get a case saver, make sure its a plastic one. the metal ones can cause more damage to the cases than if the chain hit them. Quote Link to comment Share on other sites More sharing options...
bebetekbanshee358 Posted February 7, 2010 Report Share Posted February 7, 2010 yeah man.. big up on the case saver.. my case looks like shit right now.......... Quote Link to comment Share on other sites More sharing options...
