just got a 421 cheetah cub i havent put it in yet i have 35 mm pwks now from a different motor should i use these or shoud i go with bigger carbs? what kinda power am i sacraficing by stayng with the 35mm this is a gas motor
You'd gain maybe 2hp with 39mm carbs but if you are duning or other riding the 35s will have better response and be better everywhere but at max rpm.
