Okay i have 99 and it smokes alot i have cleaned the carbs, changed gas too many times, compression tested (good), and changed the plugs,to try to fix this problem banghead it has sat for about 3 months , but before that it was fine and ran fine. Give me a shout out to try something else please.
have you checked your silencers they could be plugged up i had to re pack mine had the same problem
Is it smoking really bad at start ups? And does it smoke still after it has been warmed up? When you let the bike sit for three months, did you put new gas in? When you are adding the premix to the fuel, are you mixing it well enough? Also if it has sat for some time and your wanting to start it up. Oil will settle to the bottom of the case and gas tank. Thats why I say to shake the banshee like a shaking the baby.
Its smoking after it gets warm and im pretty sure the oil mix is correct 50 to 1 is there any certin oil i should use and it is new gas./ i just got the banshee a couple months ago from a buddy.
i mix gas at 32 to 1( 4 oz to a gal). and use a good oil remember you get what you pay for! klots oils or maybe 927
Edited by N2DEEP
I also run 32 to 1. And I run Klotz. It smells good and only smokes a little when it is cold at startup. I dont run more than 40:1. I have some Golden Spectra pre mix that actually says to run it at 64:1 which I think is way too lean but I know people that swear by it. So to each their own.
gotta couple questions, are you seeing a loss in power/ snap, are both silencers pouring heavy smoke, what does the smoke smell like, if your burning trans oil it will smell kinda like melting plastic BTW, does the smoke stay the same throughout the run, as in just starting and warmed up does it smoke less or the same?? if you could answer these questions for me
[the smoke does stay the same does not smell like burning plstic it smells like im running to rich on oil, Is what it looks like to me but the ratio is correct. Also throught the run it stays the same
the plugs look okay a little black i did not put oil in it when i stored it but i drained all the old gas out and put new in, the plugs are brand new. i have not checked the packing yet what should i look for when i take them apart.
