WantABanshee Posted December 24, 2009 Report Posted December 24, 2009 I just completley rebuilt my banshee.. (bought it in pieces) It is the first banshee I have ever owned. After fixing and having the slides in on the wrong carbs this thing RIPS!!!! It runs great everywhere. However, it hates to start and sometimes when i kick it and it doesn't start it backfires. It also will not idle. I have a 290 main jet in it with a BRAND NEW 27.5 pilot. I tried to lean out the pilot thinking that its trying to flood itself when it doesn't start so I would turn the air screw to 2 turns out and it just did not run good at all. Right now I have the air screw 1.5 turns out and it runs great just does not like to start or idle. Please help me out guys. Mods Toomey T3's Proflow filter with adaptor and no airbox lid boyseen reeds. Quote
278 Posted December 24, 2009 Report Posted December 24, 2009 If you still have your TORS system remove it, then try actually dropping the pilot jet size. Quote
cousinsracing Posted December 24, 2009 Report Posted December 24, 2009 Yes the stock tors are still on the bike but they're unplugged but I will be getting a removal kit tomorrow is the pilot too fat for my setup or will I be able to get it dialed in with the airscrew? Quote
locogato11283 Posted December 24, 2009 Report Posted December 24, 2009 your pilot size is fine. almost all aftermarket pipes require the 27.5 pilot. have you used the idle screws at all? Quote
FASTOYS Posted December 25, 2009 Report Posted December 25, 2009 Need to make sure the bowls are on the correct carbs. One has a brass BB on bottom edge of the bowl and the other bowl doesn't have one. The one with the bb goes on the left carb (w/Choke knob). Also need to sync the carbs! Quote
AKheathen Posted December 25, 2009 Report Posted December 25, 2009 did you also unplug the tors controll box? the little black box under the gas tank next to the coil, on the left.......it will not idle at all otherwise, unless you are barely touching the throttle. Quote
WantABanshee Posted December 25, 2009 Author Report Posted December 25, 2009 NO i did not disconnect the control box!!!!!! Sounds like it could be my problem Jeff I will check the bowls too... Most likely they are mixed up as well Also Jeff thanks for all the parts my man!! They all fit great!! Jeff were still having trouble getting my cousin's Keihn carbs idling still Merry Christmas everyone! Quote
FASTOYS Posted December 25, 2009 Report Posted December 25, 2009 Thank YOU. Give me a call sometime or email and i will help you more on the carbs. Quote
GNR101 Posted December 26, 2009 Report Posted December 26, 2009 damn.. i thought this post was going to be about little bugs lifting weights n shit Quote
cousinsracing Posted December 27, 2009 Report Posted December 27, 2009 just an FYI gus my cousin (wantabanshee) and I worked on our bikes and that damn little tors box next to the coil was plugged in on both of ours! so we got rid of that, bottomed out the slides, synched the carbs, set the idle screws and now both of our bike idle (neither one of them did before)! Oh and Jeff, got the throttle springs in and it is a night and day difference bro we rode all day today and it was very comfortable..thanks a lot man Quote
WantABanshee Posted December 27, 2009 Author Report Posted December 27, 2009 as stated above it runs, idles great! The DAMN thing still does not like to start!!!!!!!!!! I don't get it Am I doing something wrong? Quote
FASTOYS Posted December 27, 2009 Report Posted December 27, 2009 just an FYI gus my cousin (wantabanshee) and I worked on our bikes and that damn little tors box next to the coil was plugged in on both of ours! so we got rid of that, bottomed out the slides, synched the carbs, set the idle screws and now both of our bike idle (neither one of them did before)! Oh and Jeff, got the throttle springs in and it is a night and day difference bro we rode all day today and it was very comfortable..thanks a lot man Glad they workded out! as stated above it runs, idles great! The DAMN thing still does not like to start!!!!!!!!!! I don't get it Am I doing something wrong? Were the bowls installed correctly? Does it start better either hot or cold? Quote
WantABanshee Posted December 28, 2009 Author Report Posted December 28, 2009 Jeff the carb bowls ended up being on the right carb it starts much much much better hot... as soon as it cools down i'm screwed Quote
FASTOYS Posted December 28, 2009 Report Posted December 28, 2009 Call me and we will figure it out. Sounds lean or worn out. Quote
WantABanshee Posted December 29, 2009 Author Report Posted December 29, 2009 Thanks Jeff. I held my choke open and kicked it a few times and it started up!! Looks like I need to hold that worn out choke open!! Quote
