I have 92 banshee it came with a K & N air filter and Dg pipes front to back. Problem is I dont know if it was ever jetted or what jets to put in? It has some dead spots or bogs if you will at certain areas of excelerating. Put new plugs in today and it was popping until it warmed up an just seems like it is missing something? any help please.. Throttle response just seem liek it could be better
are u running old gas? that can make it pop. just throw in some new stuff and clean the carbs first off and go from there. imo
get in there and learn your carbs......1 at a time, so as to not mix parts up. likely needle, mains and airscrew adjustment, and possibly need cleaning anyways.....there is tons of help and info in the JETTING section to get you through it.
popping could indicate a lean condition. if the carbs were never jetted properly for the modifications, then thats more than likely the issue.
like AK said, i would take the carbs out and become familiar with them. pull the bowls off and see what jets are in there. then report back. your pilot needs to be a 27.5 and im guessing 270-300 main.
Thanks all, As far as I know no jetting has ever been done. The gas is only like 3 weeks old I just filled it when I went riding last time. I will rip carbs off and look around. Hopefully won't mess em up worse.. I did replace the throttle cable few months ago.. anything I could have messed up there?
nah not likely. has it run fine since then or not?
There has always been dead spots and bogs at times when excelerating. But it seems to be worse and just seems to have a lack of get up and go.. Like I said pipes and air filter were on and pretty sure the guy before never did anything to carbs.. after installing parts
