lowriderb Posted October 30, 2009 Report Posted October 30, 2009 ive found it either way, the extreme of each end lean or rich with either fuel is a bad situation.. the next only reason i suggested that was because the common plug colors apply and for someone first starting out before they do their home work on alcohol can get used to what they are seeing. Quote
Koolguyson Posted October 30, 2009 Report Posted October 30, 2009 ive found it either way, the extreme of each end lean or rich with either fuel is a bad situation.. the next only reason i suggested that was because the common plug colors apply and for someone first starting out before they do their home work on alcohol can get used to what they are seeing. I will agree that an alcohol plug is a little tougher to read, but ANY extremely lean motor, whether it is gas, alcohol, nitro, E85 is going to detonate and stick. However, a slightly lean alcohol motor won't kill itself like a slightly lean gas motor will. Quote
PaddleShee Posted October 30, 2009 Author Report Posted October 30, 2009 Thanks for all the information guys. At what point would you need to dip into the billet trans? How much HP can a cut stock trans hold up? I'm kinda leaning toward a 18mil or bigger to get all my weight down the track. Just not decided yet. What would be a better set up, Twister big block or a DMX? Not sure on how high the bores go on the twisters. I know the DMX's go up to 85mm........ Quote
PaddleShee Posted October 30, 2009 Author Report Posted October 30, 2009 Lol, thanks Rico. Your weight is the killer element here. 275 is not easy to move. A 10mm DM would probably get you there, but it may not like it. I would go a little bigger if it were me since cost at that point is similar with the only additional expense is crank. A 14mm DM is about as far as I would push a stock tranny too. Or you can buy my 18mm DMX and run 3.70's with you on it You got any pics of it? I bet that thing is violent when it launches.. Quote
coronakidd Posted October 31, 2009 Report Posted October 31, 2009 my 18mill d.m. has a 2-5 with billet second been running it for 3 season no problem you also should look into a twin cougar setup they are a spread bore will not fit into stock cases and billet cases have to be a spread bore then you could always do a tripple cylinder shee setup or a tripple snomo motor Quote
Koolguyson Posted October 31, 2009 Report Posted October 31, 2009 (edited) I would go DM/DMX over twister personally. Cheaper and faster. I wouldn't go cougar until they are a little more figured out. Even an 18mm DM will need a billet trans with you on it. Remember, your weight puts stress on all the parts. You don't want to cut corners on a big build. It will just cost you more in the end. Edited October 31, 2009 by Koolguyson Quote
PaddleShee Posted October 31, 2009 Author Report Posted October 31, 2009 Running a big motor I hear you have to break it down ever pass or ever couple passes to check things and make solid runs, true or false? Would you happen to know what the DMX top ends are running price wise? Koolguyson would you happen to have a pic of your bike? Quote
coronakidd Posted October 31, 2009 Report Posted October 31, 2009 Running a big motor I hear you have to break it down ever pass or ever couple passes to check things and make solid runs, true or false? Would you happen to know what the DMX top ends are running price wise? Koolguyson would you happen to have a pic of your bike? false on the tearing it down part i weigh 255 ilba never had tranny problems out of my d.m. heres my 18mill i tore it down 1 time during the middle of a season Quote
Koolguyson Posted October 31, 2009 Report Posted October 31, 2009 I don't think I have any still pictures of it. Just action shots Quote
PaddleShee Posted October 31, 2009 Author Report Posted October 31, 2009 (edited) Can one of you guys explain the lock-up clutch to me? is there weights on it you adjust? Any advice or tips for a new guy on a drag bike his first time out? Any tuning and setting up? I know it probably depends on what the motor and such is... Edited October 31, 2009 by PaddleShee Quote
Koolguyson Posted October 31, 2009 Report Posted October 31, 2009 Can one of you guys explain the lock-up clutch to me? is there weights on it you adjust? Any advice or tips for a new guy on a drag bike his first time out? Any tuning and setting up? I know it probably depends on what the motor and such is... Most of the lock up's doing manufactured right now are single stage lockers. Not really any tuning that goes into one. CPindInc is coming out with some new lock ups that will allow you to adjust the amount of slip the clutch has, but they aren't open to the public yet. Here is a video against my good friend Dennis Packard. Quote
lowriderb Posted October 31, 2009 Report Posted October 31, 2009 motor: 18mm or if your going that big may look into the 20mm's dm/dmx: billet cases is a must for reliability, the trans i would at the very very least run a billet 2nd gear set with a 1-5 override. carbs depends on the builders suggestions 39-44's is normal. pipes same again, custom built ones for that specific motor would cost a little more or which ever is found to work best at the time.. the lock up is deffinitly a must as well, the way that they work is centrifugal force pulls the arms that the weights are on out away from the center, the arms are pressing directly onto the pressure plate holding the clutches together.. with that being said, the mattoon clutch system would work better for the bigger motors i would think. Quote
Koolguyson Posted October 31, 2009 Report Posted October 31, 2009 with that being said, the mattoon clutch system would work better for the bigger motors i would think. Curious why you say that Quote
lowriderb Posted October 31, 2009 Report Posted October 31, 2009 cause its already set to hold up to the bigger motors, you dont have to have that clutch system but ive seen 8-9 plate hinson systems with extra weights on the lockup not hold to 14mm dm's torque and show better torque numbers on the same dyno with the mattoon system, and we're talking about a bigger motor than that now. Quote
KaosBanshee44 Posted October 31, 2009 Report Posted October 31, 2009 Most of the lock up's doing manufactured right now are single stage lockers. Not really any tuning that goes into one. CPindInc is coming out with some new lock ups that will allow you to adjust the amount of slip the clutch has, but they aren't open to the public yet. Here is a video against my good friend Dennis Packard. Who took that video i was sitting right behind where that video was shot. Wish i would have met a few people out there when i was there just hard to put names and faces to people i've never seen before. Maybe next year i'll meet up with some people. That guy in the white shirt from Puerto Rico was a trip we got him hammered the first day we were there. Quote
