guys tonight went out look at coolent was alittle down so i added some warmed it up ran it hard for about 30 min down the road and such now i dont know if it s buring coolent becasue after i got done riding i took the raditor cap of and it was full..... but this thing is smoking bad from the right side it looks white but i know there is no way i am that rich do u think it is somthing with my jetting or what not.... and the hole spark plug thing is if it is buring coolent what would the spark plug look like would it have anitfreeze on it?>?????
I don't know how many times we have to go over this.:rolleyes:
If the coolant is lower now than the last time you filled and rode it, your burning or leaking it.If it isn't dripping then you need to pull the head and throw a new gasket with some spray on gasket sealer,then torque down the head do a heat cycle and re-torque the head.
Edited by quikshee
Well, if you are losing coolant, and it's smoking white from the right side, I feel as though you are burning coolant. In which case you have a leak.
that was my first thought but the werid thing is is taht tonight it didnt loose any coolent and could u tell by your plugs also if coolent is getting into the cylders
